Thread: induction kit
Results 1 to 10 of 15
  1. induction kit
    I have a 2003 A3 2.0 fsi with a K&N induction kit on. The car has thrown up the engine management light a few times now and my dealer has replaced the EGR valve and the spark plugs under warranty. I was told the plugs were black with soot and that it was due to the induction kit causing over fueling. Is this true and am i going to have problems with sensors every time i do something to the engine??? My plans are the induction kit,a full exhaust system with sports cats ans a re-map once there both on and working.
    Mike
  2. Re: induction kit
    Hello???!!!
  3. Re: induction kit
    Take the induction kit off and put the standard air-box back on ASAP but with an up-rated non-oiled panel filter in such as Green or Pipercross.
    Induction kits are literally useless on anything other than a track-car being used at high speeds sucking up clean cold air. You will be risking damaging various bits of your engine because it will be used in stop-start town driving in dirty air and because of its location will be sucking up hot air from under the bonnet rather than cold air directly from the front of the grill.
    Many garages have told me VW/Audi air-boxes are good for near on 600bhp (point made with the new RS6 I suppose) and truthfully so are the standard paper filters, but a non-oiled Pipercross wont hurt and will free up a couple of bhp.
    And sorry to say K&N are probably the worse of the kits as they use oiled filters.
  4. Re: induction kit
    southampton
    Get a Pipercross Viper Induction kit as they have a carbon fibre heat shield to reduce 'heat soak' and also have a cold air flow pipe that goes directly by front grille
  5. Re: induction kit
    Or as advised put the standard air-box back on and don’t risk any harm to the engine or MAF or it sucking up water etc etc
    There is no logical reason to induction kits on normal cars other than to sell in Demon Tweaks catalogues and there is a reason why Audi/VW have spent good money designing the air-boxes to be as they are.
    As mentioned induction kits are good for track cars on the track.
    I had a Carbonio carbon fibre kit on a seriously tuned GTI 1.8T, Carbonio are meant to be the best and it actually lost power and sounded like an atmospheric dump-valve.
    The money would be better off spent elsewhere.
  6. Re: induction kit
    southampton
    Yeah but surely left 2 personal opinion?? I have never had trouble with induction kits.
  7. Re: induction kit
    Yes of course, but from experience and that of reputable tuners it is friendly advice to a fellow petrol-head.
    Personal opinion would be whether a particular body kit or wheel looked good (as long as they didn’t have any detrimental effect), but when a part has been found to cause detrimental effect then surely it is not an opinion but a word of advice/warning.
    There as parts that for some reason and ‘fashion’ cause harm to the engine and the induction kit is one of those.
    Atmospheric dump-valves don’t do any harm, but they can loose power, therefore IMO this would be a personal opinion.
    mikesA38P has had problems with his motor and it’s clearly down to having fitted an induction kit, I think he’s very lucky that the garage have already replaced parts under warranty, therefore it is my personal opinion that he should put the standard air box back on.
  8. Re: induction kit
    southampton
    Im not doubting that it is friendly advise, all im saying is that if you have used induction kits in the past with no problems, youre not going to worry about using one again (depending on what make etc) And as for using a fully atmospheric DV, from experience it makes the car run rich which can cause all sorts of problems.
  9. Re: induction kit
    Good, at least we’ve agreed on something.
    I’m glad you haven’t any resulting problems regarding your induction kit, but just think how much better your car would perform if you took it off.
    We’ve high-jacked this post a bit, so let’s gets back to helping Mike:
    Mike, put the standard air-box back on, this should hopefully sort out your problems.
  10. Re: induction kit
    southampton
    Yeah fair enough mate
  1. mk2 1.3, induction
    By golf88 in forum Golf MK2 - 1984 - 1992
    Last Post: 04-02-2008, 09:07 AM
  2. Induction kit for 1.8T
    By GavinT in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-12-2007, 01:02 AM
  3. Induction KIt
    By 1staudiA3 in forum Audi A3 - Archive Topics
    Last Post: 29-10-2007, 04:26 PM
  4. Induction Kit
    By Pod1.9TDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-08-2007, 03:11 PM
  5. A4 1.8 B5 K&N Induction Kit Yes or No
    By sanstorm999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-08-2007, 12:59 PM
