Thread: TDI alternative Engines
  1. TDI alternative Engines
    Does anyone know whether the 80 will take the newer Audi TDI engines or any other possible alternatives?
  2. Re: TDI alternative Engines
    Gwent
    Anything is possible, it's usually a question of money!
    As a starter, I guess it would be physically straightforward to put an A4 130 pd engine into an 80. This would need every engine and engine management component to be transferred. The ECU and immobiliser/key reader are linked to the instrument cluster, that may need to be transferred as well, or some other way found to overcome this? It would be best if the gearbox were swapped from the A4 as the ratio's are probably quite different. If the recipient car were petrol this would definitely be the case.
    You would probably need to do something with the fuel pump, exhaust etc.
    You might be able to fit a VW toureg 5cyl tdi 2.5, or a v6 2.5 tdi you would need to scour the vag parts bin for mounts, etc from the 5cyl/v6 petrol models?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: TDI alternative Engines
    Sounds like a bit of a nightmare! Got a mate to throw a golf diesel engine into my old T25 camper which wasn't too bad but guess times have changed!
  1. Alternative to tinting
    By Big_E in forum Vehicular windows, Glazing and Tinting
    Last Post: 19-11-2007, 02:12 AM
  2. alternative online wiring diagrams?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2007, 12:06 AM
  3. t25 type 25 alternative gearboxes!!!
    By jimmypatch in forum The Commercial Range
    Last Post: 02-09-2007, 06:24 PM
  4. T4 alternative Diesel engines
    By markAsh in forum Chat - Anything with wheels
    Last Post: 05-07-2007, 06:56 PM
  5. Alternative to concert radio cassette
    By Mike Allen in forum Audi A4 - Archive Topics
    Last Post: 04-12-2006, 02:19 PM
