Thread: Slow to Heat Up Alhambra
Results 1 to 10 of 13
  1. Slow to Heat Up Alhambra
    It takes a good 10-15 miunutes of driving before my Seat Alhambra starts to heat up so that the heater blows out hot air, the air con also takes a while to clear a misty screen. I have a 1.9tdi 02 reg model 5 years old from new. My previous car was also a seat alhambra which I had for 4 years and the heater and screen clearing using air con seemed to be much more effective. Is it just that the newer model is not as effective/efficient as the old or is there another cause I should look at. Once heated the temp guage stays exactly in the middle and it all works fine it just takes while to get there!. Appreciate any thoughts Thanks.
  2. Re: Slow to Heat Up Alhambra
    greenock(scotland)
    sounds like a thermostat buddy
    200hp 242plbs
  3. Re: Slow to Heat Up Alhambra
    Jul 2007
    I have the same problem, takes a good 10 mins drive before hot air comes out.
    Where is this thermostat can you be more specific as there are a few of them in the vehicle
  4. Re: Slow to Heat Up Alhambra
    Mar 2008
    Manchester
    Definately sounds like the thermostat is stuck open slightly. Causing the coolant to flow when the engine is cold. (Thats if there is a thermostat in your car, as on my Skoda it was completely missing causing the car never to warm up properly)
    Can I ask when driving, does your temperature gauge move down?
    Depending on the engine the thermostat is either on the engine side of the bottom hose or in radiator. However not having experience of the Alhambra don't hold me to that!
  5. Re: Slow to Heat Up Alhambra
    Mike, not sure if you've still got this problem. If so, try checking whether the auxiliary heater is working (under back left corner of the car if you're not sure - about the size of a shoebox with its own moni exhaust pipe coming off it.) The heater heats the coolant when you first start the car, to get the engine up to temperature and then later provide heat to the cabin (all via engine coolant).
    After a few minutes of driving, check the heater - if it's working, it'll be making a jet-engine noise and hot air will be blowing out of its mini exhaust (careful checking that, of course). The heater only comes on if the engine's completely cold, so no point checking after a short stop or on a warm day (I think above 7degrees is when it doesn't bother coming on).
  6. Re: Slow to Heat Up Alhambra
    dibly Guest
    yes i had this problem--mine is x reg and after changing the thermostat it was the same--its just bad in really cold weather--get a heated screen--the wiring plug is under a flap next to the n/side quarter light
  7. Re: Slow to Heat Up Alhambra
    Mar 2010
    London
    good advice dn-
    Quote Originally Posted by dibly View Post
  8. Re: Slow to Heat Up Alhambra
    Leven Scotland
    Hi there just to say I have the same problem with my Y reg 1.9 TDI, that it takes a good 15 to 20 mins to show any change with temp gauge.
    I changed the thermostat, but still no difference and I can hear a noise from under the bonnet, which I take to be the aux heater working when I switch off the engine after a short journey on a cold day.
    The gauge also reduces when I stop long enough during trips and also the engine won't heat up from cold just by sitting in the driveway.
    Thank god for the heated front seats is all I can say, hope someone on here can shed any light on this problem.
  9. Re: Slow to Heat Up Alhambra
    dibly Guest
    its the same as mine--terrible at heating up--even after a new themastate--i wondered what the noise was when i stopped
  10. Re: Slow to Heat Up Alhambra
    Apr 2007
    Hi Guys
    I have the same problem with my 2000 1.9TDI. There is a noise from the engine bay but is that not the oil pump to the turbo. It will stop as soon as you turn on the ignition.
    The heater at the rear, just forward of the rear passenger side wheel did sound like a jet engine immediately after a cold start but I have not heard that for quite some time now.
    Ivan
  1. no heat
    By sschletter in forum Passat - Archive Topics
    Last Post: 18-01-2008, 10:45 PM
  2. Heat!!!!
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 05:09 PM
  3. No heat
    By marc7 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2007, 06:28 PM
  4. Help No Heat
    By plev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-11-2007, 01:38 PM
  5. No Heat in 88 90Q
    By AdirondackQ in forum 80 - 90
    Last Post: 12-02-2007, 09:04 PM
