Thread: Alternative to concert radio cassette
  1. Alternative to concert radio cassette
    Nov 2006
    I am having major problems with my concert radio cassette. I recently purchased a refurbed unit from Audi (£235) and that lasted just an hour, before problems started. They are exchanging it for yet another unit, but if that fails as well, then i will reluctantly give up on the Audi range of players.
    So my question is, does anyone know of a suitable alternative ? Also will a normal player just plug straight in ?, i noticed that there seemed a lot more plugs in the back than the normal two. And finally are the Bose speakers compatible with a normal stereo?
    Any advice will be gratefully received.
    Regards Mike.
    london/ UK
    Hi, to conect a aftermarket stereo to the bose amplified system you will need a specific interface made by Autoleads and a set of adaptors that will bring the opening to standard DIN size. Do a search on ebay and you may be able to get them for 30-40 pounds, failing that, your local Halfords store may be able to order you one but it takes about 2 weeks as Autoleads dont keep them in stock ! Fitting is just a matter of unplugging the audi one, plug the interface in between using the original DIN conectors and plug the interface to the amp conectors.The conectors are color coded and wont go the wrong way. Also you will need to conect the blue/white remote turn on lead so the interface turns on when the ignition on and pay attention to the power wires(+12v) as when i conected mine the stereo would not keep the settings when the key was removed. Had to check the wiring with a multimeter and found that swapping the switched yellow(+12) with the red(+12) was what needed. Use a multimeter to check. Also, if you have a factory cd player, it wont work after with the bose interface but you will love the volume gain. Dont crank it too high, though. Hope this helps.
    Nov 2006
    Thanks for the detailed reply, I think i am going to keep my fingers crossed that the replacement unit is ok (3rd time lucky and all that).
    Failing that i will take your advice, and go for the autoleads solution. I was thinking of replacing the speakers as well, but your suggestion will avoid that, so thanks once again.
    regards Mike.
  4. concert radio
    Nov 2006
    Southampton
    Mike Allen,
    Is your concert radio playing up from a volume viewpoint?
    The unit is of good quality and is manufactured by Blaupunkt, the problem lies with faulty software.
    You can get other units but buying from an Audi outlet merely gives you far less for your hard earned money.
    Regards
    gazza57
    Nov 2006
    Hi Gazza,
    Yes it is the volume problem with the original unit. Then i bought a replacement unit, which worked for an hour or so, then the lights went out and i was unable to turn it off. so the original unit was fitted back in (complete with volume problem), and i am waiting for yet another replacement ----- This will be the last one, if it doesnt work, its money back time.
    I like the reply above from Adam, as it gives the most options. Although i would like to keep the original type radio as it suits the car better than most aftermarket type replacements.
    If you know of any better solutions i would be grateful for the info.
    Regards Mike.
  1. golf / vento mk3 sony radio cassette
    By vwnige in forum Vento - 1994 - 1998
    Last Post: 28-05-2007, 10:15 PM
  2. Concert radio problem.
    By Barnz in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-03-2007, 08:21 PM
  3. Golf Mk4 Gamma Radio Cassette Player
    By doriclad in forum Golf MK4 - 1999 - 2004
    Last Post: 21-11-2006, 11:42 PM
  4. Gamma Radio Cassette
    By DiverDave in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-06-2006, 09:40 AM
  5. Sharan SE - Beta Radio Cassette
    By warbum44 in forum Touran - Sharan - Caravelle
    Last Post: 28-02-2006, 11:24 PM
