Thread: 12v socket?
  1. 12v socket?
    Mar 2006
    The 12v socket in the boot of my 2002 130bhp passat seems to have blown a fuse. I've looked under the steering wheel where the fuse is supposed to be but i can't find it, can anyone help.
    london/ UK
    Usually these plugs are retrofitted so the fuse may be in a different place. Look behind the fusebox if you see any spare fuse conected to a live feed. Also pull the socket out and see if any power cable goes to it and check with a multi-meter if it has power to it. Could be that the lighter is not working !
    Jun 2006
    UK, Mids
    There should be one or two side by side - 20A yellow if still the originals.
    One for each 12v socket if there's two together.
    These are on a relay panel above the pedals.
    You need to remove lower dash panel, 2 screws on front, two on side near main fuse panel, and two clips along top edge. the fuse/s are at the bottom of relays.
    Mar 2006
    Thanks for reply but the socket used to work till a mate plugged a dodgy light into it ,and its never worked since.The hand book says it was standard fit.Any more help would be appreciated
    Mar 2006
    thanks snapdragon i will take it apart tomorrow will let you know how it goes
    Mar 2006
    managed to have a go at it today(sunday) think i have replaced right fuse it was a 20amp and was blown.thanks for excellent instructions.
  1. Diagnostic Socket - Where is it??
    By marleyp in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-06-2007, 10:04 PM
  2. Boot socket fuse?
    By bryanp in forum Passat - Archive Topics
    Last Post: 17-04-2007, 05:01 PM
  3. Trailer socket wiring
    By meltin in forum Passat - Archive Topics
    Last Post: 31-03-2007, 02:38 PM
  4. A4 Avant rear 12v socket fuse
    By Tanuki in forum Audi A4 - Archive Topics
    Last Post: 10-01-2007, 12:06 AM
