Thread: VAG-COM in scotland
  1. Unhappy VAG-COM in scotland
    Nr Falkirk
    Help can't find the right place for this so here goes.
    I have a friend at work who's VR6 isn't running right so could do with a shot of VAG-COM to identify the problem.
    I have an OBD scanner but still getting problems can anyone help
    Ta Des
  2. Re: VAG-COM in scotland
    greenock(scotland)
    is the car missfireing under load or just running bad all the time?
    200hp 242plbs
  3. Re: VAG-COM in scotland
    Nr Falkirk
    We have put new Plug leads and MAF on the car which has made the power smoother but it is decidedly slower than my VR6. I know there is some variation between cars but my current VR6 is slower than my first and his is significantly slower. I'm getting a Lambda sensor fault I think but could do with access to something better than a scanner as even with the new MAF my scanner still shows no signal from it
    Ta Des
  4. Re: VAG-COM in scotland
    Have you found a Vagcom in scotland yet?if so, where?there doesn't seem to be any in Scotland!!
  5. Re: VAG-COM in scotland
    Nr Falkirk
    NO can only suggest finding a friendly auto sparky
    Ta Des
  6. Re: VAG-COM in scotland
    Aug 2007
    I am nr Drymen and have vagcom if it helps but not necessarily the experience to solve your issue
    PM me if you are still having problem
  7. Re: VAG-COM in scotland
    Angus, Scotland
    I'm up near Aberdeen/Dundee i that's any help!
    Will be travelling down south this weekend if you are really stuck and further down south could maybe pop in on the way!!
    Paul
    A4 B7 S-Line 140 TDi
    Phantom Black, Bose Sound System, Arm-Rest, Retro-Fit DIS, Retro-Fit Cruise
    Fully registered Vag-Com/VCDS Hex-CAN
  1. Hi from Scotland
    By MacSpook in forum New Member Introductions
    Last Post: 08-02-2008, 01:34 AM
  2. greetings from scotland
    By galanc in forum New Member Introductions
    Last Post: 14-01-2008, 04:51 PM
  3. Hello from Scotland
    By ~Stef~ in forum New Member Introductions
    Last Post: 10-01-2008, 03:06 PM
  4. hello from scotland
    By DEL_BOI in forum New Member Introductions
    Last Post: 10-12-2007, 09:59 PM
  5. New Guy from Scotland!
    By OnTheJazz in forum New Member Introductions
    Last Post: 12-03-2007, 11:48 PM
