Thread: Help A3 Unable to select Reverse Gear
Results 1 to 10 of 17
  1. Help A3 Unable to select Reverse Gear
    Hello
    Hoping people can throw some light on this problem, i have 1.9 tdi a3 (130) 2002, 50k on clock(had from new).
    Car always ran find suddenly this morning went to park up and found could not / get select reverse gear, gate well and truly shut, did not force it, tried selecting reverse with engine off still no joy.The gearbox has never ever given indication of problem occuring always been sweet as nut
    I am still about to select all 6 forward gears with no probs drives ok, but no reverse so have 2 pick place to stop etc.
    Could it be clutch adjustment?? delving in the engine bay, it appears to go in 6th gear via the manually linkage. So fault appears away from gearbox.??Linkage visually appears in order.How does reversing switch connect into the linkage mechanism??? could it be this stopping it
    Any ideas
    Mark
  2. Re: Help A3 Unable to select Reverse Gear
    133 Post(s)
    1986 Post(s)
    I would think it is a linkage or box selector problem. If it was clutch related you would not get forward gears and it would select if the engine wasn't running.
  3. Re: Help A3 Unable to select Reverse Gear
    Thanks Crasher,
    Booked in with local garage for monday, they think it could be along selector lines.Is this normally expensive ??
  4. Re: Help A3 Unable to select Reverse Gear
    133 Post(s)
    1986 Post(s)
    Difficult to say on that.
  5. Re: Help A3 Unable to select Reverse Gear
    Thanks Crasher,
    the saga continues had my friend round this morning talking over the problem went through the box etc without engine running, after a bit we heard a sound like"twang" or whiring noise. After this i was able to select reverse and drive/ move car in reverse.
    Now for punchline, went to put in first gear to pull away but nothing the same in second just no drive, i can choose 3,4,5,6 and pull away.
    No drive in 1 or 2 is a case off selector broke .Any Thoughts would be appreciated.
    Mark
  6. Re: Help A3 Unable to select Reverse Gear
    133 Post(s)
    1986 Post(s)
    PM me the cars reg and your email address, I will send you some info.
  7. Re: Help A3 Unable to select Reverse Gear
    Gloucestershire
    Hi, had a similar fault with my wife's A3 just before xmas, no 1st 2nd 3rd gear or reverse, turned out to be a £8 plastic clip on the top of the gearbox, replaced that and all ok again, unsure as to whether this is the same fault as yours but it may be worth a look, there are two of these clips on the top of the gearbox.
  8. Re: Help A3 Unable to select Reverse Gear
    did these two clips prevent to you getting into gear or once there causing into jam there so you could,nt move it out again/ change
  9. Re: Help A3 Unable to select Reverse Gear
    Crasher,
    Have pm you ? did you receive it?
    thanks Mark
  10. Re: Help A3 Unable to select Reverse Gear
    Gloucestershire
    Didn't jam in gear, could never get it in!!! Pain.
  1. Aircon stops when select fan speed 3/4
    By aedmunds in forum Touran - Sharan - Caravelle
    Last Post: 24-11-2008, 12:25 AM
  2. Gear Select Problem - 96 Passat - PLEASE HELP !!!
    By rjpaterson in forum Early Passat Forum - Pre 97
    Last Post: 28-01-2008, 08:32 PM
  3. Reverse gear problem
    By kenharkin in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-11-2007, 05:51 PM
  4. reverse gear trouble. v reg a3 1.6
    By aswinsco in forum Audi A3 - Archive Topics
    Last Post: 17-10-2007, 08:55 PM
  5. Sticking reverse gear!
    By omar_K in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-08-2007, 12:32 PM
