Thread: Glow plug relay location
  1. Glow plug relay location
    Can anyone tell me where the glow plug relay is located on a 2002 Audi A6 Tdi 130? I have been having a few problems getting her started and have changed everything including the glow plugs and G62 coolant sensor. There are NO faults codes now registered on VAG-COM. When it is really cold outside (minus 1.5 the other day) the glow plug light only came on for 2 seconds, so I can only conlcude the relay is going/faulty. Any piccies would be greatly appreciated as I have a tendancy to break things whilst looking for other things.
  2. Re: Glow plug relay location
    Aug 2007
    Hook Hampshire
    21 Post(s)
    rather than change the relay put a voltmeter accross the glow plug terminal and earth and you should get 11volts for about 10 seconds. If not the change the relay
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Arrow Re: Glow plug relay location
    Thanks for your quick reply. There is current going to the glowplugs so I think that the power is simply not on for long enough. Does the relay control how long or the ecu? The strange thing is the other day when it was minus 1.5 degrees, the glow plug light came on for about 2 seconds. Yesterday, when it was plus 3 degrees, the glow plug light came on for about 4 or 5 seconds. On both occasion, the car had been left for several hours. I cant understand why that would be? If it is the relay, where is it located?
  1. 1999 Sharan location of glow plug relay?
    By SeanieMac in forum Touran - Sharan - Caravelle
    Last Post: 29-11-2008, 10:53 PM
  2. wheres my glow plug relay at???
    By rethump in forum Golf MK3 - 1993 - 1999
    Last Post: 07-04-2008, 08:19 PM
  3. Glow Plug Relay
    By mattis- in forum Golf MK3 - 1993 - 1999
    Last Post: 21-01-2008, 11:34 AM
  4. 1997 Sharan glow plug relay - where?
    By the_old_diver in forum Touran - Sharan - Caravelle
    Last Post: 19-12-2007, 07:14 PM
  5. Tdi Glow Plug Relay
    By Rob G in forum Octavia
    Last Post: 06-11-2007, 06:28 PM
