Thread: 1991 Polo CL - petrol smell with window down
  1. 1991 Polo CL - petrol smell with window down
    I've taken my car in to have a quick look at for this problem but they checked all the obvious things and the problem is still there. If I am driving at say 60MPH with the window down I can smell petrol enough to the point that we try to keep the windows closed while driving. I can't smell it at all inside the car. I'm not knowledgeable when it comes to cars, I've asked on another thread for recommendations for a decent repair garage to go to as well On a recommendation from a more knowledgeable friend, after running the car for a good long while, I've opened the bonnet and had a good look around to see if I can see anything leaking from anywhere but I can't. I think the garage I took it to checked the air filtering system but what they did didn't make any difference. I'm trying to get this problem fixed before summer
  2. Re: 1991 Polo CL - petrol smell with window down
    replace your fuel cap, they leak when they are old, esp. if you have a full tank. also check the fuel filler neck as these rust and can develop holes (if this has happene you will need a new tank) also check the breather hose in the engine bay (plugs into the botton of the airbox), as the hose can split, letting the fumes out. i doubt this will be the prob though as the fumes normally get sucked in through the heater. my money is on the fuel filler cap!
  3. Re: 1991 Polo CL - petrol smell with window down
    133 Post(s)
    1986 Post(s)
    As g40jon said, check the filler next, where it is soldered into the tank at its base.
  4. Re: 1991 Polo CL - petrol smell with window down
    I should have mentioned that the fuel tank has already been replaced, exactly a year ago. Correct me if I'm wrong, but surely if the smell is coming from a point that is past the driver's window, I wouldn't be able to smell it when doing 60MPH? On the point of the breather pipe for the fuel tank, I've tried to get it fixed before - when filling the tank, if I were to just wait until the tank is full, normally petrol delivery ought to just stop. It does, but petrol gurgles out the hole it is being put into. Not a great deal, but enough for some to dribble on the chassis. My workaround is to only put put 25 litres in when filling up, so the dribbling doesn't happen. - edit - thanks for your replies so far!
  5. Re: 1991 Polo CL - petrol smell with window down
    133 Post(s)
    1986 Post(s)
    It sounds as though you have a tank venting problem which will become worse the higher the engine speed is due to greater fuel return. This could be a trapped breather or a poor quality tank. Some tanks I have been supplied with for these cars were so poor I sent them straight back.
  1. 2000 1.8T Passat - Strong petrol smell on take off
    By biltong in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-02-2008, 08:22 PM
  2. smell of petrol / fumes in car
    By ifonly in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 07:10 PM
  3. 2.0 VW petrol smell in crankcase
    By simmo490 in forum Archive posts
    Last Post: 28-01-2008, 09:52 PM
  4. 1991 Polo GT Coupe info?
    By auto_detail in forum Chat - Anything with wheels
    Last Post: 26-10-2007, 02:15 PM
  5. VW Golf petrol smell and fuel efficiency
    By gaz2007 in forum Chat - Anything with wheels
    Last Post: 18-10-2007, 11:41 AM
