I am about to undertake A4 2001 2.5tdi QUATTRO rear dics and pad replacement.
I am unsure as to whether I will have to undo the allen head bolts that hold caliper mounting bracket OR can the disc be removed without this operation. I ask this as I believe that the Guide pins as well as the guide bolts would therefore require replacement! The guide pins look to be available only from VW/Audi? Guide pin bolts are easily available and are a couple of pound from Halfords...
If giude pins required does anyone know of the part number or item / pack that is required .......I have looked though many of the forums for A4 rear pad AND disc replacement with no real luck?
Any comments and help would be appreciated..............
anthonyj
