Thread: New member needing advice on lowering
  1. Talking New member needing advice on lowering
    Dumfries and Galloway
    Hey folks, used the search button but couldnt find what i was looking for.
    Need a but of info on how to lower a mk4 golf, how easy it is etc?? Looking to lower my mates in a couple of weeks. Is there a guide on how to do it??
    Iv done my pug so i know my way around a car.
    Help appreciated Cheers rab
  2. Re: New member needing advice on lowering
    The Back of the car is real easy you'll have both sides done in 40 minutes maybe even quicker. As for the front again it's straight forward but i bit more messing about i ended up taking all the brakes off and then taking the wheel housing from the front wishbones to make room to slide the bottom of the new shocks into its seat in the back of the wheel housing.
    my only tips are :
    don't disconect the brake lines (unless you wanna bleed the brakes after you put it all back together)
    dont pull from the driveshafts i did this and then found there was no need,
    someone else may say different but this way worked for me and my cars fine
    Dan
    1.9 TDI POWER
  3. Re: New member needing advice on lowering
    Yeah i thought the back would be easy. Took 6 hours on my 106, bloody torsion bars lol.
    Yeah the front will just be struts off and simple replacement like the 106.
    cheers for that mate needed to make sure before i started.
  4. Re: New member needing advice on lowering
    hey i got some pics
    Hope they help if not please ask
    http://www.kentkruisers.co.uk/Golf Lowering/
    Hope this helps a little
  1. New member looking for wheel advice
    By s21deg in forum Golf MK5 - 2004 - 2009
    Last Post: 26-12-2007, 02:41 PM
  2. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  3. New member - wants some advice
    By rhanney in forum New Member Introductions
    Last Post: 19-06-2007, 09:11 AM
  4. Newbie,needing advice
    By Driver1.8 in forum New Member Introductions
    Last Post: 04-05-2007, 12:35 AM
  5. Buying S3 Advice new member
    By olliea in forum New Member Introductions
    Last Post: 12-03-2007, 11:47 PM
