Thread: Noise From Climate Control When Cold
  1. Noise From Climate Control When Cold
    Dec 2007
    When I switch on the climate control on my 1.8T, when the engine is cold, I get a noise that sounds like a loose fan belt. (If I don't switch on the CC - no noise - wait a while then switch it on the noise will then occur). Would anyone have an idea as to the cause / remedy? .....and er...likely cost to fix it !!
    Andy
  2. Re: Noise From Climate Control When Cold
    Bath, Somerset
    I could be wrong but it sounds like your auxilary belt needs adjusting. When you switch the Climate on it puts extra load on the belt and it slips.. Should be a quick fix to adjust. Slightly longer if you have to replace the belt.
  3. Re: Noise From Climate Control When Cold
    idd second that, it does zap a load o power!
    VW Golf Mk4 1.8T
  4. Re: Noise From Climate Control When Cold
    Dec 2007
    Thanks for the replies gents.
    I'll check the Haynes manual to see if I might check this myself otherwise it's useful knowledge if I have to go back to a dealer.
    Andy
  1. A6 climate control / air con
    By Oakstedge in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-07-2009, 10:14 PM
  2. Cruise Control / Climate Control
    By Cian_ie in forum Archive posts
    Last Post: 27-01-2008, 08:47 AM
  3. No cold air from climate!
    By Deaks in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2007, 08:33 AM
  4. climate control
    By salty in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 28-12-2006, 10:18 AM
  5. Dual Climate - I'm getting cold!!
    By stua4 in forum Audi A4 - Archive Topics
    Last Post: 26-11-2006, 12:30 PM
