Thread: 1995 Audi A4 TDI 90BHP Smoking And Power Loss
  1. 1995 Audi A4 TDI 90BHP Smoking And Power Loss
    Nov 2006
    I'm currently suffering from loss of power and smoking with my Audi A4. I did have a tune box fitted but have now removed it. The car is fine around town, but when accelerating from 70 - 80mph there is a power loss and smoke is produced. I read in an earlier post a similar problem and the guys replying recommended a replacement MFU.
    Any suggestions would be great as it's driving me nuts and killing the planet!
    Chris
    Oct 2006
    I would look at changing the MAF (inlet airflow sensor). Try unplugging it and test driving. If it makes no difference then it usually denotes a dud MAF. Mafs can be cleaned with electrical cleaner and blow dry with compressed air. But it may be passed that.
    Or could be something simple like a blocked airfilter. I've seen a diesel filter that had been through a puddle and got it soggy and was also full of leaves.
  3. Tested Disconnecting MAF Last Night
    Nov 2006
    Drove the car last night with the MAF disconnected and basically it drove without the turbo working. I then reconnected the MAF and instantly the car was ok again. Tested it again this morning coming into work and it's back to it's normal tricks - flat spots and smoking.
    Could this be a MAF?
    london/ UK
    Run a bottle of injector cleaner trough the tank. How many miles on the clock, are the nozzles original ? Did you replace the filters(air and diesel) ? If the car is high milleage, i would remove the turbo, the inlet manifold and the EGR valve, and clean them as there will be a lot of carbon build up ! Another thing to check on high milleage cars is the catalyst, as it plugs off if the engine gets overfilled with oil ! Also check the temp sensors as when duff, the ECU its confused and uses default values(limp mode) to protect engine. Ask someone with a Vag-com to scan the modules for you and post the codes(if any !) on the forum.
  5. Vehicle Details
    Nov 2006
    I have run injector cleaner through with no success. The car has 138,000 miles on the clock. The air filter has been replaced, but not diesel.
    I have read about cleaning the inlet manifold as it can become blocked with carbon/soot. How easy is this to do?
    Nov 2006
    i had a similiar problem it was the thick rubber hose from the turbo to the fixed plastic pipe that goes round the top of the engine it had a hole in it.
  1. Audi A4 tdi loss of power
    By siddlem in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2007, 09:07 PM
  2. audi a6 power steering fluid loss
    By nigepet in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-01-2007, 09:32 PM
  3. audi 80 electrical power loss
    By draddog60 in forum 80 - 90
    Last Post: 15-10-2006, 03:08 PM
  4. Passat 1.9Tdi PD 130 - Power loss & excessive smoking (from front too)
    By quantummech in forum Passat - Archive Topics
    Last Post: 02-08-2006, 08:10 PM
  5. audi 80 loss of power
    By gabby in forum 80 - 90
    Last Post: 11-01-2006, 11:42 PM
