Thread: Handbrake only acting on 1 wheel
  1. Handbrake only acting on 1 wheel
    Mar 2007
    Fife
    A couple of months ago the travel in my handbrake lever increased a lot. I put this down to cable stretch or brake pad wear. However, at the weekend I had the car on axle stands (for fuel filter change) and noticed my handbrake is only acting on the rear nearside wheel.
    Before I start taking off exhaust heat shield and stuff to access the cables, does anyone have any ideas where the failure is most likely to be. Perhaps the link to the brake calliper at the wheel itself?
    Any suggestions greatfully appreciated.
    Ta
    A4Chris
    1997 Audi A4 1.8T Sport
  2. Re: Handbrake only acting on 1 wheel
    JDA Guest
    Similar problem on my 1995 A4 2.6 quattro, (222000 mls) disconnected passenger side cable @ the brake caliper found that cable was seized. New UniPart cable (from Partco in the UK) fitted problem cured.
    Cable is awkward to fit, trim around hand brake lever has to be removed, fit string to cable end @ hand brake lever, this makes it easier to pull the new cable through.
    The new cable can be fitted without removing the heat shield, although it helps to bend the shield for better access
  3. Re: Handbrake only acting on 1 wheel
    Mar 2007
    Fife
    Thanks for that. That's an impressive mileage on your 2.6 by the way! Just goes to show Audi's will run and run if well maintained.
    Mines going in for MOT on Monday so I'll either have a look at the handbrake this weekend or be lazy and let the local garage fix it!!!
    A4Chris
  4. Re: Handbrake only acting on 1 wheel
    JDA Guest
    I am near Glasgow, bought the car with 170000mls, ex Company car since then oil (10W/40 semi synthetic) & filter change every 4000mls, uses 0.5 L oil between changes, fuel consumption 22 - 34 MPG,
  1. Replies: 7
    Last Post: 21-02-2008, 03:15 PM
  2. Rev counter&Speedo acting strange
    By pepino_gordo in forum Bora - 1998 - 2005
    Last Post: 13-02-2008, 01:42 PM
  3. passat acting up
    By jstahl20 in forum Passat - Archive Topics
    Last Post: 08-12-2007, 09:08 PM
  4. factory alarm acting up
    By da_bomb2001 in forum Golf MK3 - 1993 - 1999
    Last Post: 24-10-2007, 01:54 PM
  5. Help, my Bora is acting up
    By darren74 in forum Bora - 1998 - 2005
    Last Post: 01-02-2007, 03:29 PM
