Thread: Misfiring Mk4 1.8T
  1. Misfiring Mk4 1.8T
    Right the other thread got a lil messy and it wasnt even mine to start with. I have a Mk4 Golf 1.8T that is suffering from a misfire some of the time. It occurs at startup 95% of the time (Has done it twice when driving from cold). When it occurs the car only fires on what seems like 2 or 3 cylinders. It is possible to keep the engine running, and if i do so for 20-30 seconds, the misfire goes away.
    I have had 2 breathers changed as they were found to be faulty (holes in both). Althought this seemed to sort the problem it has not gone away.
    I have changed the plugs but this has not solved the problem.
    I plan to clean the throttle body when i get over my illness as this has been recomended by Crasher. It has had a little clean but nothin thorough.
    I have the VAGCOM diagnostic results also;
    17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P1200 - 35-00 -
    16795 - Secondary Air Injection System (B2) - Incorrect Flow
    or Secondary Air Injection System: Incorrect Flow Detected : P0411
    16684 - Random Misfire Detected - Any Cylinder
    or Random/Multiple Cylinder Misfire Detected : P0300
    16688 - Cylinder #4 - Misfire Detected
    or Cylinder 4 Misfire Detected : P0304
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) : P1297
    16685 - Cylinder #1 - Misfire Detected
    or Cylinder 1 Misfire Detected : P0301
    16687 - Cylinder #3 - Misfire Detected
    or Cylinder 3 Misfire Detected : P0303
    17956 - Boost Pressure Regulation Valve (N75): Open Circuit : P1548
    I have checked the functionallity of the Diverter Valve by disconnecting it and attempting to suck air through the 3mm tube. It seems to be functioning as i could not 'suck' air through it.
    Just wanted you guys to look at the VAGCOM results and add your 2p worth
  2. Re: Misfiring Mk4 1.8T
    do these problems usually occur together? or does it sound like more than one cause?
    cheers
    VW Golf Mk4 1.8T
  3. Re: Misfiring Mk4 1.8T
    Hyde
    Im not familiar with your engine at all, but I once had a similar fault on a Vaux Astra, the cure was a new EGR valve, quite common on that make/model
  1. 2006 A6 misfiring?
    By Red-penquin in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-11-2008, 11:22 AM
  2. VW Bora 1.6 8v Misfiring?.
    By PLukE in forum Bora - 1998 - 2005
    Last Post: 20-01-2008, 08:05 PM
  3. Urgent Help, Misfiring??.
    By PLukE in forum Archive posts
    Last Post: 08-01-2008, 10:26 AM
  4. 98 s4 misfiring...
    By the lemster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-12-2007, 03:08 PM
  5. A4 misfiring please help
    By thegasman2000 in forum Audi A4 - Archive Topics
    Last Post: 03-02-2007, 10:17 PM
