Thread: electrical problem on golf mk3
  1. electrical problem on golf mk3
    Nov 2006
    PLEASE HELP
    Just bought a 51 plate golf TDi and its starting to play up.You can be driving normally and then the radio and dash lights go off for a second or two then they turn back on but the time clock resets to 00:00 .Sometimes when it happens the engine revs drop as though its going to stall.
  2. Loose Connection
    Jan 2006
    Belfast, Ireland
    Sounds like a loose connection there somewhere. Most probally a loose earthing wire, or could even be a loose fuse or relay. But this is definitely your problem, this causes all the symptoms you described.
  1. Mk2 Golf GTi Electrical problem
    By keith52 in forum Golf MK2 - 1984 - 1992
    Last Post: 10-11-2007, 02:34 PM
  2. Electrical Problem MK4 Golf
    By alzgoh in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2007, 09:54 AM
  3. electrical problem golf 1.3
    By Nelson in forum Archive posts
    Last Post: 02-10-2006, 01:58 PM
  4. Golf 1.3 cl 1988 engine electrical problem?
    Last Post: 30-09-2006, 12:04 PM
  5. golf mk3 electrical or starter problem?
    By joeparnell in forum Golf MK3 - 1993 - 1999
    Last Post: 08-09-2006, 11:22 AM
