Thread: Rear parking sensor`
  1. Rear parking sensor`
    Hi all.
    Does anybody know where I can get hold of a single parking sensor? Audi have diagnosed a fault with the left side sensor on my A3 and quoted me £170 just for the part. At Vag Parts it's £170 for the complete set of 4 sensor and loom.
    I kon wit's just one sensor that's gone so I was hoping I could just buy one. If anyone's got one knocking about or knows of somewhere I can get one please let me know.
    No singular ones on ebay either.
    Cheers.
    Butler.
  2. Re: Rear parking sensor`
    ChrisIDS Guest
    Hi Butler,
    The parking sensors are ultrasonic transmitters and receivers. There are four, so I assume two are transmitters and two are receivers. Which ones are which on the bumper, I don't know ! They are not complex parts; just a high-frequency microphone and speaker, effectively. The transmitter transmits a short, high-frequency pulse, which is reflected by the object you -don't- want to reverse into and received by the receiver. The distance is determined by the time it takes for the signal to be received; the further away the object, the longer it takes for the signal to return.
    You can buy these raw parts, in pairs (one Tx, one Rx) from maplin.co.uk, about £5 a pair.
    http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
    They are fairly standard components, used in thousands of different applications and devices, so it -may- be possible to retrofit this devices into the existing moulding/casing.
    All this, of course, is just a guess from an electonics engineer and these parts may not be suitable, due to size, etc. But, for five squids, it's surely worth investigating :-)
    Cheers,
    Chris
  3. Re: Rear parking sensor`
    ChrisIDS.
    Great effort. There is A maplins 5 mins from my house. It's worth a shot.
    In the mean time if anyone finds a place that sell the proper Audi parts singularly, just in case this doesn't work. I'd greatly appreciate it.
    Many thanks.
    Butler.
  4. Re: Rear parking sensor`
    Southampton, U.K.
    Each sensor is in fact a transceiver (they transmit and receive).
    I'd be very surprised if you could attach any old sensor to a factory fitted system.
    As Chris should well know (being an engineer), the sensor will have individual characteristics which are generally calibrated by the head unit/controller.
    Therefore, attaching a sensor from a different system will likely mean one of the following:
    a) It won't work at all
    b) The sensitivity will be either too high or too low
    if you can't find a one off sensor for your system, then go for the VAG parts set. At least you'll have spares for the future!
    How beautiful it is to do nothing, and then to sit down afterwards, and rest.............
  5. Re: Rear parking sensor`
    I was thinking all the sensors sent and received. Otherwise the width or the car might not be covered. Thanks for clearing that up for me.
    I've not found anywhere as yet. My main problem is that I don't really want to splash out £170 right now. I'm trying to save for my wedding!
    I can live without the help this would give me anyway for a while until a cheaper alternative comes my way. I'll just use my eyes!
    Butler.
  1. Looking for an OEM/Second Hand Parking Sensor System
    By bobmac892 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:25 PM
  2. Audi Orig. Parking sensor alternatives
    By wokfm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-01-2008, 08:07 PM
  3. A6 Parking sensor problem
    By oysamson in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-10-2007, 04:31 PM
  4. Taurus T123 Parking Sensor
    By Celtic Cousin in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-09-2007, 06:34 PM
  5. FS: Passat B5.5 parking sensor kit (estate)
    By Carps in forum Passat - Archive Topics
    Last Post: 09-02-2007, 06:27 PM
