Thread: Audi A4 130 Tdi 2003 - Indicator Lights Fault
  1. Unhappy Audi A4 130 Tdi 2003 - Indicator Lights Fault
    I have developed a fault on my Audi. The onboard computer flashed up to say that the left front indicator light was not working. I arranged for the bulb to be replaced and the new bulb work for all or about 10 minutes and then the computer flashed up again to say there was a fault.
    I have checked the bulb and it is working. The same fault has now appeared on the right side too.
    The fault has not affected the Side indicator light (on the Wing) nor the Rear indicator lights.
    Does anyone know what the problem might be and how i set out repairing it?
  2. Re: Audi A4 130 Tdi 2003 - Indicator Lights Fault
    Mar 2008
    The bulb holder burns out, you'l see very slight marking on the holder if you remove it. Can sometimes get away with new holders but you maybe looking at a new headlight.
  3. Re: Audi A4 130 Tdi 2003 - Indicator Lights Fault
    May 2008
    did you have any joy with this as my A4 is doing the same
  4. Re: Audi A4 130 Tdi 2003 - Indicator Lights Fault
    hi there m8 ive had the same problem with my audi on the adjacent side .
    I have ended up buying a new headlight unit i had water damage around the connectors and have caused the indicator to stop working i bought a brand new 1 from my audi specialists for £76.69+vat
  1. TT Indicator Fault
    By trcopping in forum TT - 8N Forum - 1998 - 2006
    Last Post: 13-02-2009, 12:44 AM
  2. 04 Passat Dashboard Indicator Lights
    By westerboyz in forum Passat - Archive Topics
    Last Post: 26-01-2008, 10:22 PM
  3. VW Caravelle 2003. Indicator light bumb replacement
    By lennygriff in forum Touran - Sharan - Caravelle
    Last Post: 17-01-2008, 10:29 AM
  4. Indicator/Electrical Wiring Fault?
    By Mattster in forum Golf MK3 - 1993 - 1999
    Last Post: 27-11-2007, 08:25 PM
  5. 2003 Passat ABS Fault
    By J warden in forum Archive posts
    Last Post: 14-10-2007, 05:06 PM
