Thread: Is the the gearbox or clutch
  1. Is the the gearbox or clutch
    Im new to these forum's but can anybody help
    Ive got a 99 Golf Cab(MK3/4) 1.8.
    Whilst driving the other day i went to change into 3rd gear and the pedal went all the way to the floor as if the cable had snapped, i got the car home and on inspection the cable aint snapped.
    The pedal goes straight to the floor when pressed but dont return.
    Can anybody please help me as wether its the gearbox or clutch,the car had a clutch fitted last year(only coverd 6000-7000miles since)
  2. Re: Is the the gearbox or clutch
    Hi If you find no fault with the clutch pedal,wire,or the release shaft lever,(the part the wire is attached to at the side of the gearbox)Then i think you will find the lever which presses the push rod to free the clutch is split on its splines.There is a large green disc on the end of the gearbox,remove this and you will see the lever.
  3. Re: Is the the gearbox or clutch
    A BIG Thanks to Kenney, You was spot on with your reply so you saved me loads of money.
    cheers
    thanks again
    dazz
  4. Re: Is the the gearbox or clutch
    Mar 2007
    My Golf pedal snapped yesterday (sounds similar to the problem stated). Kenney, can you let me know how best to get it repaired (i.e. complete new pedal, have a mechanic weld it, etc), plus what sort of cost I'm looking at?? Thanks
  5. Re: Is the the gearbox or clutch
    The first you need to check if it is the pedal or the wire that is broken, if not,then it most surely is the lever in the gearbox This is not a difficult job,you remove the green plate on the end of the gearbox to access the lever.I dont think it would pay you to weld this part for all the price of it.
  6. Re: Is the the gearbox or clutch
    Jan 2009
    when removing the green disc will i loose gear box oil and i assume te disc will then need repacing if so where can i get one?.
    ta dave
  7. Re: Is the the gearbox or clutch
    Hi A little,and not enough to worry about.Jack the car up, on the one side only.You will however need to replace the disc.
  1. Clutch/Gearbox Problems with TDi130
    By mcaizmb2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 06:02 PM
  2. Golf mk4 clutch / Gearbox
    By sim69bed in forum Chat - Anything with wheels
    Last Post: 16-11-2007, 10:33 PM
  3. clutch/gearbox issue
    By Deyhimyg in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-10-2007, 01:44 PM
  4. Polo 1.1 Gearbox failure? or clutch? lol
    By Blunder babe in forum Polo - Derby - Lupo - Fox
    Last Post: 29-09-2007, 01:11 AM
  5. New GearBox/ Clutch anyone?
    By AudiSport in forum Audi A3 - Archive Topics
    Last Post: 24-01-2007, 07:27 PM
