Thread: 1997 cabriolet
  1. 1997 cabriolet
    May 2007
    Afternoon all,
    another question (two actually!) after a day of tinkering. I havent got a manual yet so hopefully these daft questions will dry up soon!
    I plan on changing the bake fluid soon - I have a pressure bleeder and have done it before on other cars I've had. Is there a difference between dot 4 and dot 5.1 brake fluids that make them incompatible?
    And now for the really dorky question - does my car cave a hydraulic or cable clutch, please? I cant see any evidence of either!
    Jim
  2. Re: 1997 cabriolet
    Jun 2007
    Gwent
    Hi
    I'm not too sure about the fluid but I have a feeling dot 4 is mineral based and 5.1 is silicone? If so, probably should not be mixed!
    The clutch will be hydraulic, the master cylinder may have a hose going to the brake fluid reservoir? In other words it shares the brake fluid? The slave cylinder is mounted on top of the gearbox and behind the bell housing, so difficult to see and work on!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: 1997 cabriolet
    May 2007
    Thanks Scotty, After much grubbing around I did find the clutch slave cylinder. Spot on again, cheers Jim
  1. 1997 1.8 Cabriolet
    By JimSharp39 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-02-2008, 09:53 PM
  2. 1997 Cabriolet aux gauges
    Last Post: 13-02-2008, 11:43 AM
  3. A6 Cabriolet
    By rudivisser in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 20-11-2007, 10:30 PM
  4. Which A4 Cabriolet?
    By zeratul in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2007, 12:55 AM
  5. A4 cabriolet
    By ribster in forum Audi A4 - Archive Topics
    Last Post: 04-01-2007, 09:02 PM
