Thread: AUDI 80 K reg tappet noise!!!
  1. AUDI 80 K reg tappet noise!!!
    the audi 80
    Hi, i've just spent a load of money getting the beast through MOT, a month later and i think i have a noisy Tappet.
    The noise is nice and regular with the engine and increases with revs.
    The engine is the 1.9tdi, i wondered whether they were automatic adjustment (oil) or manual. I which case, how can i fix this annoying noise?
    Cheers Peeps!
  2. Re: AUDI 80 K reg tappet noise!!!
    Gwent
    The tappets are oil filled and self adjusting. Some people say flushing oils can cure noisy tappets but I think these treatments are not great for the engine as they strip out beneficial deposits as well as bad ones! fully synthetic oils can also help, but the problem tends to come back sooner or later.
    to change the tappets, the valve cover and camshaft have to be removed, make a note of the position and orientation of each cam bearing cap, retorque to correct value. Consider changing the timing belt while your in there?
    cheapest source for tappets I have seen is here;
    http://sites.internet.lu/folders/cus...OR%20PARTS
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Rocker/tappet jumped at 2.5 tdi V6
    By viodiesel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-10-2015, 10:37 AM
  2. AUDI A6 Rattling Noise & Blue Smoke- HELP
    By grigor in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-12-2007, 11:51 PM
  3. 2002 Golf making tappet noises?
    By tkblueyonder in forum Golf MK4 - 1999 - 2004
    Last Post: 12-10-2007, 12:46 AM
  4. 2003 A4 1.9tdi tappet problem
    By thomas spain in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-06-2007, 06:02 PM
  5. 2003 A4 1.9tdi tappet problem
    Last Post: 25-06-2007, 05:57 PM
