Has the car abs ? If it has ,then chances are that air got into the pump and will need bleeding( see the procedure on rosstech site !) with diagnostic equipment-Vag com. Also you may wanna bleed the brakes and chech the biasing valve on the back of the car as when they stick it does make bleeding a pain in the butt.
