Thread: t4 injectors
  1. t4 injectors
    Sep 2007
    hi,got a t4 2.5tdi transporter,anybody no anything about the injectors? i have a set of replacment injectors genuine vw bosch ones, four std ones look the same,but the electronic one looks longer.have been told by supplyer they are interchangable.on my van the electronic one is on no4 cyl,this one looks like it fits on no5, does it make any differance witch cyl the electronic one go's in?
  2. Re: t4 injectors
    Herman.58 Guest
    If you have a position sensor on no 4 at the mo it means you must have an 88hp 2.5 which is fitted with stanadyne injectors. If your replacements are bosch it means they come from a 102hp. This has needle postion sensor on cylinder 5. you can fit them to your van, (what size are the injectors .195???) but, you will need to get a different longer fuel pipe to reach injector no 5 coz your current pipe wont reach the Bosch injector. its longer.
  3. Re: t4 injectors
    Sep 2007
    thanks for the reply,i'l get a new pipe and fit them, thanks
  4. Re: t4 injectors
    Sep 2007
    hi herman.58 sorry the reply took so long,you asked me if the injectors were .195 cant see that on them.the bosch no is 0432 193 663 (937) 68123a5 and the vw no is 074130201 j bpx then 220/300 bar does this mean anything to you?do you think it will need a remap after fitting? thanks
  5. Re: t4 injectors
    Mar 2006
    Hi Billy,
    Not sure what you have here....Are you fitting 102 injectors to an 88 ?
    If so you'll need the fuel pipe for pot 5 off an ACV.
    You will then need a remap as you will be changing the fuelling.
    You must also have an intercooler fitted as if not you will smoke like a factory...
    If you are going this far....then I'd fit new nozzles too, .216's that I use will get you to 155 bhp....
    Catch ya later.
    Ron.
  6. Smile Re: t4 injectors
    May 2009
    Huddersfield
    216's????
    Can i have a contact number??
    I would love to get some of these.
    cheers
  7. Re: t4 injectors
    Mar 2006
    Quote Originally Posted by t4acv View Post
    216's????
    cheers
    Just mail me at
    Rake_722@hotmail.com
  1. 0.216 Injectors
    By OzzyDan in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2008, 10:58 PM
  2. injectors
    By BROWN_OWL in forum Golf MK5 - 2004 - 2009
    Last Post: 24-12-2007, 05:02 PM
  3. Mk 5 2.0 TDi injectors
    By Davieboy in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2007, 08:29 PM
  4. 2.0 FSI Injectors
    By Raiters in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-10-2007, 03:40 PM
  5. tdi injectors
    By mikeya4 in forum Audi A4 - Archive Topics
    Last Post: 05-07-2007, 11:04 PM
