Thread: TDI Electrical problems
  1. Question TDI Electrical problems
    worthing
    Hi All. I have a Passat tdi 130 2002 With electical problem. Side lights work, main head lights don't, beam works on flash but not when you switch them on, hazzards work but not the indicators, heater works but the blowers don't any ideas? Thanks in advance Stephen
  2. Re: TDI Electrical problems
    Have you checked the fuse box? Its on the side of the drivers side console (only visible when you open the door. It may be as simple as some blown fuses
  3. Re: TDI Electrical problems
    Hi The faults you have, there are two possibilitys,they share two components which each can cause the problem (1) X-contact relief relay, control number (213) position 2 on the fuse carrier,(2) the electrical part on the ignition switch,To illiminate the one from the other,you need to bridge 2 wires behind the ignition switch.The yellow on black wire and any one of the red wires,if everything works, then it is a faulty ignition switch,
  4. Re: TDI Electrical problems
    worthing
    Thanks Kenny, This would also explain having to giggle the key occasionally to get it started. does this also mean I'll need a new Key?
  5. Re: TDI Electrical problems
    No just the electrical part of the ignition switch
  1. A3 Electrical Problems
    By Bdog600 in forum Audi A3 - Archive Topics
    Last Post: 26-01-2008, 09:29 AM
  2. A3 Electrical Problems
    By Bdog600 in forum Archive posts
    Last Post: 26-01-2008, 09:13 AM
  3. electrical problems
    By suzihawkes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2007, 12:11 AM
  4. Electrical problems with my polo....help!!
    By Gillybean in forum Polo - Derby - Lupo - Fox
    Last Post: 20-08-2007, 11:40 PM
  5. Electrical Problems
    By chairman_mo in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-08-2007, 02:07 PM
