Thread: 1.9 TDi 1997 Air sucking noise help please!!!!
  1. Talking 1.9 TDi 1997 Air sucking noise help please!!!!
    I have a 1997 1.9 tdi Golf. It has been very good for ages but within the last few weeks it has started to make a noise that sounds like air being sucked into the manifold as soon as I reach 2000RPM. It does not do it when stationary and with the air box removed I can stall the engine by holding my hand over the air intake which would suggest that all the air tubes are in tact and there are no loose hoses. I have physically checked all the hoses and they seem fine. Could it be the waste gate on the turbo? Although there is no sign of power loss. The noise is loud enough to be heard over the running of the engine.
    So come on all you techno boffins have a brain storm and please come up with something new for me to check. Thanx in advance. Gary P
  2. Re: 1.9 TDi 1997 Air sucking noise help please!!!!
    Feb 2007
    Hi mate, i`m having a similar problem apart from on mine it has lost power aswell. Regarding blocking the air supply and the car stalling, I dont think this would indicate your hoses are ok, as a small leak could be causing the noise, , but if there is a hole /split in a hose it wouldnt be large enough to allow enough air in to run the car. Hope that makes sense .
    I`ll update my topic if I find a solution so keep an eye on it ....here is a link to it .
    Dan
    https://www.vwaudiforum.co.uk/forum/s...ad.php?t=27499
  1. Audi 80 Tdi Not Sucking Diesel
    By ghee60 in forum 80 - 90
    Last Post: 13-06-2010, 04:39 PM
  2. 1997 1.8 T Sport: WIND NOISE
    By A4Chris in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-02-2008, 03:49 AM
  3. Turbo Sucking Air?
    By Dunks in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2008, 08:28 PM
  4. Noise in front of engine 2.6 A6 Avant 1997
    By Johan Slump in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 21-07-2007, 04:34 AM
  5. sucking pipes mk4 tdi 115
    By dreamworx in forum Golf MK4 - 1999 - 2004
    Last Post: 18-12-2006, 12:25 PM
