Thread: Headlight Switch Illumination
  1. Headlight Switch Illumination
    Jul 2007
    A, A
    Last night wifey reported that the illumination on the main lighting switch blinked for a while then petered out completely. Easy fix or complete dash dismantle? (I can guess the answer!)
    thanks,
    colin
    2019 A4 Avant Sport 35 TFSI Mythos Black
    2015 MX5 2.0 Sport Nav Meteor Grey
  2. Re: Headlight Switch Illumination
    Mine did this, then seems to have fixed itself after I unplugged the switch and plugged it back in again.
  3. Re: Headlight Switch Illumination
    Jul 2007
    A, A
    Thanks for that!
    It seems to be an intermittent problem. Same thing happened today - it was OK for the first half of her journey, then it spluttered for a bit, then went completely out again.
    Does the switch pull out from the front?
    cheers,
    col
  4. Re: Headlight Switch Illumination
    Hi to remove the switch, press light switch knob in and simultaneously turn it clockwise Hold switch in this position then pull the switch out of switch housing
  5. Re: Headlight Switch Illumination
    Jul 2007
    A, A
    I've just had a quick goog and found an American article about how to fit a boost gauge.
    http://www.podi.ca/Installation.aspx
    It included the following method for removing the lighting switch. Does anyone know if there's a variation of this method for UK B6's that don't have an 'auto' position please?
    To access the wiring you grasp the headlight switch
    Push the center part of the headlight switch inwards
    Twist the switch clockwise between the '0' and 'Auto' marks and it should catch and stay depressed
    Now you can gently pull the entire headlight switch out
  6. Re: Headlight Switch Illumination
    Jul 2007
    A, A
    You beat me to it! Thanks again,
    col
  1. cd illumination
    By gibo.drum in forum Archive posts
    Last Post: 05-12-2007, 01:30 PM
  2. illumination
    By mick1 in forum Bora - 1998 - 2005
    Last Post: 02-12-2007, 08:18 PM
  3. Replacing Headlight Dip Switch Stalk
    By funbox in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-11-2007, 01:22 PM
  4. Headlight switch bulbs gone
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 08:35 PM
  5. VW Passat Headlight Converter switch
    By ianadie in forum Passat - Archive Topics
    Last Post: 12-07-2006, 09:24 PM
