Thread: VR6 Starts then Stalls
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. VR6 Starts then Stalls
    Hi, I've just bought a fairly tidy '95 Golf VR6 which is mainly sound but has one odd starting problem that didn't occur in the first week I had it but now occurs all the time.
    When starting the car at any temperature, the engine fires up nicely, runs at the right RPM and then, after a second or so, stalls. After a few attempts (between 2 and 20) it will generally catch itself as it stalls and manages to recover (followed by 5 secs or so of high rpm tickover). If the car is hot, it still tries to stall but seems to be better at recovering (manily starts in a 1 or 2 attempts). I've replaced the thermostat (needed done anyway), both temperature sensors on the thermostat housing and also taken the immob out of circuit to check whether this was the issue. None of these things have made a difference to the starting problem. On the upside though, changing the thermostat has improved mpg.
    I should add, it never cuts out when running and I don't think I'm seeing any missing/hesitation.
    A mate suggested the ignition switch but I don't see why the slight temperature dependence would exist if the ignition switch was dropping out.
    I've also checked it out with vag-com but now that I have replaces the temp sender, everything reports back as fine.
    If anyone has any thoughts, please let me know and I'll post an update to say how I've got on.
    Cheers,
  2. Re: VR6 Starts then Stalls
    Manchester, England
    Sounds very similar to a fault i had on my Golf GTI, it would start randomly and cut out a second later, also had some running issues with it though. Running issues turned out to be a faulty ignition coil, and cutting out issues have been fixed since i removed the reader coil from the ignition barrel and re fitted it.
  3. Re: VR6 Starts then Stalls
    Okay, this sounds very promising. I'm pretty sure the coil pack is good but there has been one oddity with the ignition barrel already (for some reason the switched feed to the radio just stopped working). I wasn't aware though that there is a reader coil in the ignition barrel.
    Could you have a shot at describing where the reader coil is on the ignition barrel? Is it tough to remove?
    Thanks for the response, iep.
  4. Re: VR6 Starts then Stalls
    Manchester, England
    It may be different on the VR6 but i would assume its going to be similar, someone else more qualified may be able to confirm, but basically i took off all the covers around the steering colum and the reader coil is located around the ignition barrell, i have attached the picture i took when doing this, quality isnt great but it should be ok.
    I just followed the cable back to where it was plugged in took the unit off checked that it was ok and plugged it back in, havent had any starting problems since doing this. I did order a new coil but the connecter was different so i didnt end up using it. It also helps if you have long thin arms as following the cable back and getting your arm up into the dashboard can be a bit tricky
  5. Re: VR6 Starts then Stalls
    Thanks again. Useful info. I took a quick look at mine over lunch and it looks pretty much the same. For the record, I also (on a colleagues recommendation) bought a new fuel pump relay. Made no difference.
    I'll trace that coil reader wire back later on and give the connection a quick clean as you recommend.
  6. Re: VR6 Starts then Stalls
    131 Post(s)
    1978 Post(s)
    The fuel pump relay hardly ever fails but the ECU relays do. It is the one at position 3 with 109 printed on top and is VW part number 1J0 906 381 A and costs £13.48. I suggest you have a fault code read done before you go any further. During 95, VW switched to a throttle body with stepper motor control for the idle from the previous separate idle valve, which does yours have?
  7. Re: VR6 Starts then Stalls
    Hi Crasher. Wish I' known that before. Never mind though. I'm happy to spend another £13.48 if it will fix it.
    I've searched for fault codes using VAG-COM and apparently everything is fine. No fault codes at all since I replaced temp sender (G62).
    Not totally sure whether I have the idle valve or stepper motor. I know what a stepper motor throttle body should look like (I had a stepper on my last car, 98 polo) and I don't see anything like that so possibly the idle valve version. Does that indicate anything to you?
    Currently I'm starting to suspect the fuel pump and have ordered a fuel pressure test kit to check it out. I'll keep you posted.
  8. Re: VR6 Starts then Stalls
    Just rechecked engine with VAG_COM and noticed that the air intake temperature was 61.6 degrees (pretty much fixed). Needless to say, Edinburgh is more like 10 degrees right now. I'm guessing this sensor is dead but not a short or open circuit and so does not flag up an error (since 61.6 degrees might just be feasible for the car if it were in scary hot parts of the world). Either way, does anyone know where the air intake temp sesnor lives on a 95 golf vr6? Thanks again.
  9. Re: VR6 Starts then Stalls
    131 Post(s)
    1978 Post(s)
    It is on the side of the inlet manifold on the runner for cylinder six and it reads a very high temp due to its position.
  10. Re: VR6 Starts then Stalls
    Hi Crasher, found it this morning and unplugged. Made no difference. Will reconnect this afternoon and make sure that it starts at a low temp before heating up. Thanks for the advice.
    New observation is that the engine keeps runnign fine as long as I keep cranking. If I blip the throttle it responds nicely, no problem. Then, release the key back to normal 'run' position and the engine stalls immediately.
    Could be ignition switch itself? Anyone know of any other comp[onents that could cause this. Since it continues to run fine if the ignition is still in the 'crank' position I can't believe that it is fuel startvation any more.
  1. mk3 97 gti 8v occasionally stalls when clutch disengaged
    By svenema in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 10:43 PM
  2. vw 1.2 stalls
    By dawnie in forum Archive posts
    Last Post: 25-09-2007, 01:36 PM
  3. a3 starts and stalls
    By dolly in forum Audi A3 - Archive Topics
    Last Post: 05-06-2007, 06:01 PM
  4. Mk3 Golf Engine Stalls
    By JamieLoganUk in forum Golf MK3 - 1993 - 1999
    Last Post: 07-03-2006, 06:47 PM
  5. 1991 80SE Nearly stalls after ignition ?
    By tattersfield in forum 80 - 90
    Last Post: 25-10-2005, 11:19 AM
