Thread: Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
  1. Question Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
    Hello everyone,
    I'm after a bit of advice please!! I drive an '04 plate 2.0 A4 FSi SE and recently had a few captions come up on the dashboard-specifically the ESP, Engine Management and Emissions light!
    I think the ESP and Management lights are a result of the Emissions light (Safety thing maybe?) since I got the fault codes downloaded and the only 2 were a Misfire and more concerningly Exhaust Gas Recirculation System!!
    Its done around 75k miles and recently had a water pump change due to a leak-since the front was off I also got the cambelt changed instead of at 80k miles (tight i know!) I think these issues started after that but cannot say for sure as they would illuminate but then clear after i shut down and restarted the engine!
    The techy i spoke to mumbled something about EGR valves and taking out throttle bodies(!) but he didn't sound convinced!!
    Any ideas/advice etc would be massively apprecated!!
    also can someone please explain what the recirc system does as i thought only turbos needed needed that type of system!!
    Many thanks!!
  2. Re: Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
    I had a similar thing happen on my 2001 1.8t with similar miles, there was a lack of power, and both of those lights were on the dash. It was the air mass meter. 70 quid from audi, easy to fit. Not sure if a non turbo car has the same system but it was a similar error code diagnosis from what I remember.
  3. Re: Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
    Sep 2007
    sounds like a MAF fault to me i had the same problem . Replaced the Mass Air Flow Meter and all the lights cleared .
  4. Re: Dashboard lit up like a xmas tree! Serious performance issues! Upset Owner!
    131 Post(s)
    1976 Post(s)
    A fault code read should show you what is wrong.
  1. 2000 A4 1.8 20v (non turbo) performance and economy issues
    By manojluhar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2007, 06:11 PM
  2. Performance Issues on Bora TDi 1.9 Diesel 85 kw
    By SlamG in forum Bora - 1998 - 2005
    Last Post: 07-12-2007, 09:54 AM
  3. new audi owner... whats best performance upgrade??
    By 1999silverB5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2007, 06:23 PM
  4. A3 Performance Issues
    By jawadh007 in forum Audi A3 - Archive Topics
    Last Post: 07-06-2007, 07:50 PM
  5. Newbie with 93 80tdi performance issues
    By Ryan80 in forum 80 - 90
    Last Post: 11-04-2007, 09:44 AM
