Thread: ABS Kicking in at very slow speeds
  1. ABS Kicking in at very slow speeds
    Hi there, I was hoping someone out there has had the same problem as I have and could suggest a remedy.
    The ABS on my 2002 TDi 130 is kicking in when I am coming to a slow complete stop. It feels like the brakes are grinding and the pedal shudders.
    This only happens when I am going extremely slowly...less than 10mph. I have tried an emergency stop from 70mph on a deserted road and the ABS worked perfectly.
    The front discs and pads are brand new, and I have replaced both front ABS sensors. There are no fault codes stored in the ECU and the ABS light has never come on. My local dealer reckons the ABS pump needs replacing but they can not be sure. They have also quoted £700, which is not only pricy but they can not guarantee it will cure the fault.
    Any help is greatly appreciated.
    Many thanks.
  2. Re: ABS Kicking in at very slow speeds
    Ashbourne Derbyshire UK
    I'm not sure this is relevent, but my 98 B5's ABS only worked when at speeds above 7 MPH, so that when slowing down in an emergency stop the ABS worked pulsing the brakes unitll below 7 MPH then locked the wheels for the last few yards ( last 1/2 second or so ).
    Once owned 98 1.8 ADR SE non turbo passat estate(The Mrs wrote it off)
    Now own 03 TDI 130 Sport 6 Speed passat estate
  3. Re: ABS Kicking in at very slow speeds
    May 2007
    hi check the ring that goes round the hub behind the disc i have the exact same thing on my van the sensor reads the wheel to see if its moving or not there is a ring behind disc that this sensor faces if there is a bit missing the abs thinks wheels have locked and kick in it won't fail an mot on it its just very annoying!!
  4. Re: ABS Kicking in at very slow speeds
    Nov 2006
    I have just cured the same problem with my 2003 tdi sport, as with yours, mine started doing it just after fitting new pads and discs.
    I removed the rotation sensors and gave them a clean, but I also bled through a couple of 100 cc's of brake fluid, so I'm not certain which one solved the problem.
    But when the new discs and pads were fitted, the pistons were pushed back in which forced the old fluid back into the reservoir which I suspect might have sent some muck back into the ABS unit.
    Either way it has cured the problem.
  5. Re: ABS Kicking in at very slow speeds
    Dec 2007
    cheltenham
    Quote Originally Posted by angrydad View Post
    Many thanks.
    see my reply under: ABS activation at very slow speeds. tonyp1
  6. Re: ABS Kicking in at very slow speeds
    Ireland
    Had the same problem on a previous car. Cleaned the wheel speed sensors -problen solved.
  1. VW Passat Tdi Sport 130 2002 - Loss of Power - Turbo not kicking in
    By iworld in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2013, 07:34 PM
  2. Polo overheating - fan not kicking in.
    By polo 91 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-01-2008, 10:21 AM
  3. Car Swaying At High Speeds
    By mhd143 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-11-2007, 01:20 PM
  4. '97 A4 ABS coming on with light braking at slow speeds
    By HTinVT in forum Audi A4 - Archive Topics
    Last Post: 03-11-2007, 12:49 AM
  5. smoking when driving at slow cruise speeds
    By onzarob in forum Archive posts
    Last Post: 14-03-2007, 10:20 AM
