Thread: Heater Quick Question!
  1. Heater Quick Question!
    Near Blackpool
    48 Post(s)
    I am pretty sure that my heater resister pack has broke had same problem on my 306, only speed 4 works so i am guessing as that is full speed the power will not need to be resisted hence why it just "works". i have ordered a new resistor pack if indeed it is that that has failed, but where does it live, is it next to the heater moter under the glove box? or is it like my 306 where its hidden down the inlet pipe, i would go out and buy a haynes manuel but i thought i would seek the gurus on here first
  2. Re: Heater Quick Question!
    Southampton, UK.
    Remove two or three screws that hold the trim in place underneath the glovebox. The heater blower resistor is the size of a packet of Swan matches and plugs into the ducting with an electrical connector (4 wires, I think).
    The symptoms you describe are identical to mine. Fan only worked on full.
  3. Thumbs up Re: Heater Quick Question!
    Near Blackpool
    48 Post(s)
    All sorted now thanks! Took out the bottom box under the glove box, its like a little shelf, there were 5 screws. Then like you said just pulled the resister pack out, there were two harness connecters, one with 4 or 5 wires in and one with 2 wires, swopped them over and immediately had 4 fan speeds again!
  1. Quick Question
    By NoX in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-10-2008, 02:51 PM
  2. Just a quick question
    By Ben9 in forum Vento - 1994 - 1998
    Last Post: 25-12-2007, 08:38 PM
  3. New to the site.. Quick question?
    By tweeky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 05:40 PM
  4. Just a quick question
    By Ayd in forum Chat - Completely Off Topic
    Last Post: 13-08-2007, 05:21 PM
  5. Quick question
    By spiderlover in forum Chat - Completely Off Topic
    Last Post: 19-02-2007, 07:22 PM
