Thread: Nokia car kit
Results 1 to 9 of 9
  1. Nokia car kit
    Hello, I'm new to the forum, took delivery of 2004 plate A4 1.8t quattro a couple of days ago, so far I love it. There is a Nokia car kit fitted to the car but I am unsure as to what model phone will fit, can anyone please help.
  2. Re: Nokia car kit
    Bournemouth
    welcome to the site
    we'll need a little more info to help you out. can you take a picture of the phone cradle? someone may recognise it.
    any part numbers written on it etc?
  3. Re: Nokia car kit
    Dec 2006
    Wiltshire
    We would need the model number of the actual hide away box or a photo of the cradle. If it's a bluetooth kit most of the Nokia phones will work even with some limited functionallity.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  4. Re: Nokia car kit
    Thanks for the replies, I would prefer to use my Sony Ericsson in the car, is it possible to change cradles and if so where would I get one from.
  5. Re: Nokia car kit
    Dec 2006
    Wiltshire
    It may be but without seeing the current kit or knowing what it is, we can't really help you.
    And avoid original SE car kits like the plague, they are hopeless.
  6. Re: Nokia car kit
    Up North
    Quote Originally Posted by bluesky View Post
    Try searching for bluetooth accessories on your phone while in the car with the engine running.
    If it finds a car kit, you probably have a Nokia CK-7W. Look on the Nokia site for the manual, where you will get the access code (probably 0000). Connect to it and hey presto, you have a working car kit that doesn't need the holder. Will go with most phones, including Sony and Motorola.
    If it doesn't find anything, chances are it is an old CARK-91, which Nokia was pensioning off about 2004/5. This only works with real old phones like the 6310i. It's as much use as a wax kettle and needs slinging out.
    If you have to go for a new kit, take a look at Parrot. I've had nothing but trouble with the four Nokia kits I've had.
  7. Re: Nokia car kit
    If your kit is the same as mine (A4 2003) then Nokia 6230/6230i will fit. I decided to change the phone instead of changing the adapter (to some bluetooth) because that phone is ok and original adapter is also the charger.
  8. Re: Nokia car kit
    Jul 2019
    Wrexham
    Hi at the risk of being 16 years to late! I have just bought an A4 2003 with a CARK-91 kit fitted. Before seeing this thread I thought it might be a Nokia 5110 that worked. It doesn't by the way. However, after reading this thread, I don't know if it's the phone or the CARK-91 that is faulty. Any ideas please.
  9. Re: Nokia car kit
    Up North
    As per my 15 year old post, the CARK-91 is so old that Alec Issigonis had one fitted in his 1959 Austin Mini. Open the control box and you'll find it full of thermionic glass valves connected to a crystal radio set.
    Congratulations though on being able to cope with a phone so old and dumb I'm not even sure if it has Bluetooth. I'd suggest at the very least buy a Bluetooth car kit and chuck the CARK-91 in a skip. You might need a newer phone to go with it.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
