Thread: Slow Wipers
Results 1 to 9 of 9
  1. Slow Wipers
    walsall uk
    Hi I have Audi A6 TDi 2001 Y, I have problems with my windscreen wipers!!! They are very slow! Very annoying when I need them immediatly & dangerous. Even at high speed (number 3 wiper speed) they are very slow. when its cold they are extremly slow....can anyone help ?????? Any ideas?????
  2. Re: Slow Wipers
    Hi A common fault, and it is the spindels, which the wiper arms are screwed to, that are seizing in their bushes.
  3. Re: Slow Wipers
    walsall uk
    Can you please tell me what to do to make them normal please....especially in this weather i need them working....if you can explain i will follow your instructions...thanks
  4. Re: Slow Wipers
    Jul 2007
    I had the same thing on my A6. Had to get the linkage changed - Skoda garage that supplied the car did it for just over a hundred quid parts and labour.
  5. Re: Slow Wipers
    Dec 2007
    Surrey
    You can do it yourself , get the new or from breakers the arms with the splined bushes in ,its fiddly but make sure the wipers are in the return position and stay like that Wiper motor is under plastic tray in the skuttle ,take all that off Then you will see the wiper motor [ tip - get paper and pen and draw picture of arm position and bushes ---- so you know its right when you put it back --- or take pic with mobile ! ] Undo nuts on wiperblade arms and prize off the arms [ flat bladed s/driver ] Then undo arm nut on motor ,remove the arms and put it back in reverse order
    Hope this helps if not get someone else to do it !
  6. Re: Slow Wipers
    walsall uk
    Thanks i will try that ...really appreciate your response and will let you know if it worked!!
  7. Re: Slow Wipers
    walsall uk
    thanx matey, ive done that took everything out they were jammed solid. so i heated it using bunsen burner they became unjammed theyre working perfect now but i need to re align them now as theyre all over the place!!
  8. Re: Slow Wipers
    walsall uk
    hi my wipers were jammed as you now, but theyr working now but i need to correctly position them any ideas??? they go too low down. i have tried everything by adjusting their positions. does the arms underneath needs adjusting????
  9. Re: Slow Wipers
    Aug 2007
    Wicklow
    Set the short arm (that bolts to the motor shaft) at a 2 degree angle to the main frame of the arm assembly towards the passanger side. Then position your wipers on the splines and they will return to this position constantly. Also, grease inside the assembly if refurbishing.
  1. Front wipers slow
    By pricey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-10-2009, 09:58 PM
  2. Go Slow Sharan
    By tona955 in forum Touran - Sharan - Caravelle
    Last Post: 12-02-2008, 01:14 AM
  3. Slow!!!
    By rsymes2k in forum Archive posts
    Last Post: 08-10-2007, 12:02 PM
  4. Slow Wipers
    By tails in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2007, 05:37 PM
  5. MkIV Golf Wipers Dead Slow on all Settings
    By Jackjack in forum Golf MK4 - 1999 - 2004
    Last Post: 29-04-2007, 08:14 PM
