Thread: Loose Wire????
  1. Loose Wire????
    Jul 2006
    Whilst having a poke around the engine on my 1.8se (1999) APT engine today I noticed a wire with a two pin plug at the end dangling loose under the intake manifold. The pin is pink/purple in colour and has a retaining clip attached to it.
    The wire seems to come from a two wire loom where one branches off to a connection on the sump or just above it (oil pressure/level??) Having looked high and low I cant seem to find anywhere that this second wire goes!!
    The car drives fine and no warning lights are on, I've checked the expansion tank and around the fans etc but cant seem to pin point where it goes!
    Any pointers please.....
  2. Re: Loose Wire????
    Oct 2007
    Hi What colour are the two wires
  3. Re: Loose Wire????
    Jul 2006
    Hi, had a quick look with atorch and theres a green and yellowish wire and a brown and white wire....
  4. Re: Loose Wire????
    Oct 2007
    Hi checked wire diagrams for both APT and ARG engines there is no 2 polet connector in the engine bay with the colours you mention
  5. Re: Loose Wire????
    Jul 2006
    Thanks for the reply, ill have a closer look later today as it was dark last night and if possible ill take a picture
  6. Re: Loose Wire????
    Jul 2006
    Had another look, definitely a green wire with a yellow stripe and a smaller brown wire with a white stripe. The two wires go into a 2 pin plug which has a retaining clip and a rubber grommet/sheath at the top.
    thanks for the help
  1. compressor air outlet loose
    By sayloday in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 08:41 AM
  2. loose intercooler pipe! please help!
    By y2mash in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-09-2007, 05:17 PM
  3. Bora - Loose Air con unit?
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 26-06-2007, 12:02 AM
  4. Loose wire
    By Cara2007 in forum Archive posts
    Last Post: 27-04-2007, 11:23 PM
  5. Loose Gearbox
    By mUNKI in forum Golf MK2 - 1984 - 1992
    Last Post: 13-10-2006, 10:50 PM
