Thread: brake & warning lights
  1. brake & warning lights
    My 2001 A4 2.5 TDI Quattro has the 2 rear wing brake lights perminatly on!
    But not the window high level light, also the glow plug warning light is flashing &
    the ESP warning lamp illuminates. With the engine off & keys out the brake
    lights work OK!! . Please help
  2. Re: brake & warning lights
    Hi Have you changed any rear bulbs recently? if not. Then it sounds like you have a problem with the brake light switch you need to get a fault code read
  3. Re: brake & warning lights
    Yes i changed rear stop/tail bulb about 3 weeks ago.
  4. Re: brake & warning lights
    Then the first thing you need to see if you have put the right bulbs in
  1. brake and abs warning lights after xenons switched on
    By andy5468 in forum Audi A4 - Archive Topics
    Last Post: 25-01-2008, 07:53 PM
  2. brake lights / brake switch recurring nightmare!
    By stuart40 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 11:23 PM
  3. 02 Golf TDi Engine Management Warning and Brake Lights
    By nhi336 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-04-2007, 10:29 AM
  4. Brake warning lights
    By drewster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2007, 05:33 PM
  5. Brake Warning lights
    By westie383 in forum Passat - Archive Topics
    Last Post: 16-03-2006, 10:29 PM
