Hello All,
I've got a 1.8 T-Sport that is getting a build up of pressure in the petrol tank - to the point that if I don't open the filler cap every so often fuel leaks out around the filler cap (when I do release the cap fuel vapour hisses out quite agressively).
I gather that there is an EVAP Canister which releases pressure, so it could be a fault on this (or maybe the electronics/power to it??). Is this a Garage only fix or can a bloke with ten thumbs and a broken screwdriver look into it?
Ta
