Thread: Need HELP! with emissions for re-test Thursday
Results 1 to 9 of 9
  1. Exclamation Need HELP! with emissions for re-test Thursday
    Ive got the MOT re-test thursday afternoon.
    Its now failed twice on emissions
    Bit of history 1st.
    Bought the car off a friend, it hadnt been used for about 8 months, it woz only 3months after the MOT, when it got parked up. About £600 was put into passing it.
    It had to be kept at work, but it needed to moved out of the way daily, it woz started & drove bout 20-30 yards or so each day, the battery regularily needing a charge to start.
    I picked the car up drove it home, it woz running a bit rough, not surprised after the lack of use. took it for an MOT see whats what.
    Emissions, CV boot an tyre valve trapped by the hub cap, with an advisory about exhaust - so no probz there then lol
    Emissions Test:
    Natural Idle Test:
    RPM: --- not checked
    CO % vol: --- Max value-0.500, actual-0.613 - fail
    Fast Idle Test:
    CO %vol: --- max value-0.300, actual-0.008 - pass
    HC ppm vol: --- max value-200, actual-6 - pass
    Lambda: --- min value-0.970 max value-1030, actual-1.007 - pass
    Second Fast Idle Test: - not checked
    Bought new sparks, air filter, full exhaust system.
    replaced CV boot with universal stick together type, an sorted tyre valve.
    Back to MOT centre - Failed on brakes, exhaust, CV boot an emissions ***?? I woz not a happy bunny
    Ive posted about the brakes prob, parts arriving 2morow
    The exhaust bolts between, Cat. Conv & downpipe had loosened a bit, or i hadnt done the job properly in the 1st place lol
    The emissions results were different to last time
    Natural Idle Test:
    RPM 1/min: --- min limit - 710, max limit - 1010, actual value - 881 - pass
    CO %vol: --- max limit is 0.500, actual value - 0.491 - pass
    Fast Idle Test:
    RPM 1/min: --- min-2450, Max-3050 Actual-2734 - pass
    CO %vol: --- max-0.300, actual-0.620 - fail
    HC ppm vol: --- max-200, actual-110 - pass
    Lambda: --- min-0.970, max-1.030, actual-1.140 - fail
    RPM 1/min: --- min-2450, max-3050 Actual-2708 - pass
    CO %vol: --- max-0.300, actual-0.661 - fail
    HC ppm vol: --- max-200, actual-133 - pass
    Lambda: --- min-0.970, max-1.030, actual-1.121 - fail
    Oil Temp deg C: --- min-80, actual-87 - pass
    Bought a VAG-COM, trial version 409.1, got errors
    00520 - Air Mass / Air Flow Sensor (G70)/(G19)
    31-10 - Open or Short to Ground - Intermittent
    00523 - Intake Air Temp Sensor (G42)
    30-10 - Open or Short to B+ - Intermittent
    Have been told that, the MAF error can come up if the car hasnt been used, and the battery has been removed, which is has.
    The solution is to run it a few times, should clear the error,
    but it could be a genuine error, i dont want to throw £103 (cheapest i can find) at it, if its not the prob,
    nor do I wanna throw £69 (cheapest ....) into a lambda sensor, if thats not at fault, could the Lambda reading have been caused by the cat & pipe not being mated properly ??
    Any help would be gratefully received, like I said re-test thurs :S
  2. Re: Need HELP! with emissions for re-test Thursday
    Hi ya mate where you from cos i can do diagnostics on VW,AUDI,SKODA,SEAT...!!!!!
    And reset any error codes it is produceing...!!!!!
    Plus i also do mileage correction...!!!!
    Checkout my webpage which has contact details on:- Removed as per forum rules!
    Last edited by stuart; 13-02-2008 at 01:51 PM. Reason: Unauthorised advertisement - see the rules!
  3. Re: Need HELP! with emissions for re-test Thursday
    [quote=VAG.Direct;128452]Hi ya mate where you from cos i can do diagnostics on VW,AUDI,SKODA,SEAT...!!!!!
    Hiya mate
    thanx 4 responce,
    im about 90 miles south from donny
    Wot is mileage correction? soz if that soundz thick lol
    Last edited by stuart; 13-02-2008 at 01:52 PM. Reason: Unauthorised advertisment - see rules!
  4. Re: Need HELP! with emissions for re-test Thursday
    So has any1 got any ideas to
    whats causing these readings?
    What do i do next?
    Ive had to cancel the re-test
    Ive removed the piping between air filter and throttle, does my throttle need to be adapted thru the ecu ??
    Cud it be anythin else? that'll make it run rich?
    T'99 B5 Passat 1.6i ahl
  5. Re: Need HELP! with emissions for re-test Thursday
    Sep 2007
    North Wales
    I am sure I have read on this forum somewhere that, the ECU adapts to the ruuning conditions, so if it has only been used for short journeys or just idleing the ecu has adapted the mixture!
    Could just be coked up, I would suggest a good blast down a bypass if it was legal.
    Steve. 2002 (52) Passat 1.9 TDi 130bhp (AWX)
  6. Re: Need HELP! with emissions for re-test Thursday
    Feb 2004
    Yorkshire
    49 Post(s)
    Please read ALL the forum rules regarding promotion of Companies before posting links. Only OFFICIAL sponsors/banner advertisers are allowed to advertise.
    Please contact advertise@vwaudiforum.co.uk if you wish to sponsor the site.
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  7. Re: Need HELP! with emissions for re-test Thursday
    Hiya steve
    Thanx 4 ya responce
    I have to confess it has been drivin down the back lanes :S for testing only!! ive driven about 60miles testing over the last few weeks, that hasnt cleared it
  8. Re: Need HELP! with emissions for re-test Thursday
    Go and invest £8.00 in a can of forte diesel treatment and a new fuel filter pour the forte into the new filter fit the filter then blast ur way down to the mot centre it will pass the emission test
    Ed
  9. Re: Need HELP! with emissions for re-test Thursday
    Quote Originally Posted by Eddie View Post
    Hiya Eddie
    Thanx 4 ya responce, i like it lol
    is there a version for petrol ?
  1. Westec Perfromance are moving this Thursday!!!
    By grantos in forum Archive posts
    Last Post: 29-03-2005, 04:45 PM
