Thread: A4 TDI 1.9 Engine Base Unit
Results 1 to 8 of 8
  1. A4 TDI 1.9 Engine Base Unit
    vargula Guest
    does anyone know that if I get my base engine replaced on my A4 TDI 1.9
    (the part number 038100098DX, the actual part photo is here with text in German
    http://nnp.be/NNP-Shop/vmchk/Audi/A4...ypage_nnp.html
    ...that if I get this part replaced would my engine number change (i.e need to know to tally with logbook)
    Cheers & Thanks
    Es
  2. Re: A4 TDI 1.9 Engine Base Unit
    Sep 2007
    yorkshire
    It will have a different engine number stamped on the block than yours, if thats what you mean!
    2003 AUDI AVANT SPORT TDI
  3. Re: A4 TDI 1.9 Engine Base Unit
    vargula Guest
    Quote Originally Posted by passat>sport View Post
    Yes, sorry for being so green, I just need to put an explanation (if it was different) in the vehicle's service history.
    The bit I was not sure about was whether it was just on the VIN plate = current log book match or actually on a part of the A4 1.9 TDi engine that the *Base Unit* (i.e. that part number I quoted) would be expected to fully replace with the swop.
    i.e New base unit = complete engine, new number, right?
    many thanks for your help, I am very grateful!
  4. Re: A4 TDI 1.9 Engine Base Unit
    Sep 2007
    yorkshire
    All you need to do is change the engine then send the V5 off to the dvla with the new engine number. Whats gone wrong with the old lump then?
  5. Re: A4 TDI 1.9 Engine Base Unit
    vargula Guest
    Thanks for that recommendation, very clear now, much appreciated.
    Old Lump? H20. Floods of it!
  6. Re: A4 TDI 1.9 Engine Base Unit
    Sep 2007
    yorkshire
    Quote Originally Posted by vargula View Post
    Whats the damage? They can be fixed you know, as long as the rod hasn't snapped and broke the cylinder block.
    I have some rods for your engine if it is only bent rods!
  7. Re: A4 TDI 1.9 Engine Base Unit
    vargula Guest
    Thats very kind, it was a submerse unfortunately, no its knackered I'm consisdering options. Ive had it looked at and a swop was the best path suggested.
    I know its a follow-up question but I have not got anywhere with web searches on where to find the stamped-in number on the metal itself. Can you drop us a hint fof where to shine my torch?
    Ta again.
  8. Re: A4 TDI 1.9 Engine Base Unit
    Sep 2007
    yorkshire
    I've never looked to be honest! Take a look at the link.
    Left is the cam-belt area, right is gearbox.
    http://forums.tdiclub.com/showthread...52#post1859852
    It's where the oil filter housing is located.
  1. Aerial Base Replacement
    By onloantoton in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2007, 09:34 PM
  2. engine control unit relay
    By Dollso in forum Golf MK3 - 1993 - 1999
    Last Post: 02-11-2007, 03:40 PM
  3. Teutonic_Tamer touching base
    By Teutonic_Tamer in forum New Member Introductions
    Last Post: 28-11-2006, 08:58 AM
