Thread: Air Conditioning/Motor Flap Problem 2004 Passat
Results 1 to 9 of 9
  1. Air Conditioning/Motor Flap Problem 2004 Passat
    I have a 2004 Passat & recently the Climatronic AC has stopped working i.e. it won't cool. The gas etc has been checked & is ok.
    According to the local VW garage the motor flap is broken, to have a replacement they're quoting me £75 for the part and £900 labour as the dash has to come out.
    I king of feel I'm getting stung here! Can anyone offer any advice?
    Is this a job I can do myself with my mechanic mate's help? Are there any special precautions to be taken in removing the dash (air bags etc)?
    VW garage indicated that it was not an unusual fault so was wondering if anyone else on here has been through it?
    Many thanks in advance
  2. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Apologies for the 'bump' but any help very much appreciated, Thank you.
  3. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    A, A
    People have done it with just taking the glovebox out.
    Which flap is not working, V68, V70 or V71 ?????
    Have you had them reset with a vVAG COM to see if there just stuck or have lost there position.
    Just another B7 Estate
  4. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Hi thanks for the reply. It's the V68, I haven't tried resetting it yet. I don't have VAGCOM as yet but I'm hopefully borrowing a code reader/clearer(Gendan) from a colleague and will try that at the weekend.
    Any further info gratefully received, thank you
  5. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    A, A
    Quote Originally Posted by funbox View Post
    Im not sure if a code reader will work, but a VAG COM will do it.
    Where are you located, maybe there is a local member with a VAG COM.
  6. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Jun 2006
    UK, Mids
    A generic code reader will only pickup safety/emmission codes specified in the OBD standards, not manufacturer-specific ones such as this.
    I think this is located behind the centre console low down.
    I think the flap is donated by a red 'rack' (as in rack ad pinion) sticking out of the HVAC box. I think you can see it by removing the glovebox, and maybe a piece of plastic above the carpet in the footwell on the side of the centre console. This is how it is on a similar Skoda,
  7. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Aug 2007
    I posted the same in an earlier thread about your problem.
    I had a motor replaced and it cost me £170 parts and labour.
    The dash did'nt need to come out.
  8. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Dec 2007
    wigan
    how do you recalibrate it with vag com...??????????????????
    Passat Tdi 130 Sport
    Audi RS4 alloys polished alloy fronts
    no mod's
  9. Re: Air Conditioning/Motor Flap Problem 2004 Passat
    Make sure the centre boss of the aircon compressor is rotating when you select auto and drop the selected temp to the lowest setting, could be a bad conection on the clutch supply wire, I have had this on both my Passats (one was unplugged after a service and the other was rubbed through by the aircon pipe)
  1. airflow flap motor
    By mart2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2013, 01:27 AM
  2. Touran Cooling Fans and 'Intake manifold flap motor problem?
    By Matt B in forum Touran - Sharan - Caravelle
    Last Post: 02-10-2009, 01:09 PM
  3. Air flap motor
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2008, 10:19 PM
  4. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
  5. Touran Cooling Fans and 'Intake manifold flap motor problem?
    Last Post: 03-01-2007, 03:55 PM
