Thread: Changing front springs - how difficult is it?
  1. Changing front springs - how difficult is it?
    Hi, when I was diagnosing another problem on my car today (1.8 SE) I noticed that my front nearside spring had snapped!!! A small ring from the top of the shock seems to have snapped off! Has anyone changed these before? Looking and the haynes manual it seems strait forward enough?? The part from GSF is only £33, and i'd rather do the it myself if it is not too difficult?
    Any comments?
    Greg
  2. Re: Changing front springs - how difficult is it?
    134 Post(s)
    2022 Post(s)
    Easy as long as the top arm to hub carrier bolt comes out. The alignment of the strut top plate to the spring fork is very critical, if the strut has to be twisted to allow the front fork to pass over the lower arm, wheel alignment will be thrown out
  3. Re: Changing front springs - how difficult is it?
    Cheers Crasher, just had a look in haynes and cant see anything about undoing this top arm to hub carrier bolt? All it says in undo the two strut bolts from inside the engine bay located under 2 rubber grommets and the bolt holding the strut fork to the lower control arm?? The strut should then come out whole?
    Greg
  4. Re: Changing front springs - how difficult is it?
    134 Post(s)
    2022 Post(s)
    The two top arms are connected to the top plate and the inner bolts won’t come out in situ as they hit the body so they have to come out with the strut. PM me your reg and email address and I will send you some info.
  1. changing front lower spoiler?
    By choimaloy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-09-2010, 05:45 PM
  2. Broken Front Springs
    By gckimber in forum Superb
    Last Post: 26-05-2008, 09:25 PM
  3. Changing Front Bumper.
    By Ben in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-08-2007, 10:36 PM
  4. Changing front indicator bulbs
    By devin in forum Audi A4 - Archive Topics
    Last Post: 14-02-2007, 06:55 PM
  5. Changing a bulb. Is it so difficult?
    By hallgreen in forum Audi A3 - Archive Topics
    Last Post: 01-12-2006, 07:43 PM
