Thread: passat coolant in exhaust
Results 1 to 10 of 10
  1. passat coolant in exhaust
    I am new to the club. I have a 1997 Passat TDI and am having trouble. The car has 130000 miles. It is getting coolant in the exhaust. I have had the head gasket replaced 2 times and it is still happening. It runs perfect, but after 60 miles the coolant light comes on and it needs filling. I had the belts replaced with the water pump at the same time. Could it be the turbo? Any thoughts?
    thanks
  2. Re: passat coolant in exhaust
    132 Post(s)
    1979 Post(s)
    Was the head pressure tested last time it was off?
  3. Re: passat coolant in exhaust
    I agree with crasher pressure test it and if its been off twice may need a slight skimming(some ppl dont tighten them correctly)
    Ed
  4. Re: passat coolant in exhaust
    132 Post(s)
    1979 Post(s)
    On the subject of re-facing a TDI head VAG's opinion of that is
    "Reworking diesel cylinder heads is not permissible".
  5. Re: passat coolant in exhaust
    Surely the tolerances cant be that close to take of a couple of teeny weeny thou
    Ed
  6. Re: passat coolant in exhaust
    132 Post(s)
    1979 Post(s)
    You are allowed 0.1-mm distortion and any more than that means it is a big paper weight according to VW and I don't argue with that, I just fit a new Mahle or KS head.
  7. Re: passat coolant in exhaust
    are we talkin breaking into oil galleries if you skim any further tha 0.1mm or do the valve seats suffer sounds very unservicable to me with tolerances that low.Oh the old days when you just fitted a thicker copper head gasket to keep comp as standard then it would blow again 6 mnths down the line lol
    Ed
  8. Re: passat coolant in exhaust
    132 Post(s)
    1979 Post(s)
    You can't even skim the head 0.1-mm, that is the allowable tolerance for re-assembly without skimming. I don't know what their reasoning is; it can’t be cam timing (moving the centre line of cam and crank closer together advances the timing) as TDI cams are on a cone fitting. It used to be an issue with the indirect injection engines due to the steel pre-combustion chambers which caused machine shops problems with their cutting tools.
  9. Re: passat coolant in exhaust
    Yeah the old austin 2.5 diesels had a habit of dropping pre-comb chamber bits onto the piston crown they used to crack and drop down the bore then the head would crack between the valve seats and open up a water gallery goodnight vienna
    Ed
  10. Re: passat coolant in exhaust
    132 Post(s)
    1979 Post(s)
    I have had a few AAZ engines do that, one was our own hack of a Golf 3.
  1. passat 1.8t blue smoke from exhaust
    By csmccoll68 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 10:40 PM
  2. Passat exhaust rubbling
    By ashab02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-01-2008, 12:54 PM
  3. passat coolant problem
    By turbohead in forum Passat - Archive Topics
    Last Post: 13-12-2007, 01:07 AM
  4. Coolant Leak in to exhaust?!
    By richjthorpe in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-11-2007, 10:30 PM
  5. Passat, why does is use so much coolant?
    By jefo1970 in forum Passat - Archive Topics
    Last Post: 31-10-2006, 02:34 PM
