Thread: Help needed badly 1999 tdi
  1. Help needed badly 1999 tdi
    iv had a major f**k up and need help.
    1999 golf tdi, had to replace fuel temp sensor in the pump. i cocked up and removed the wrong section to start, removed the section below the temp senso, the part with what looked like a plunger, fitted it straight back on after checking the seal. continued to replace the sensor.
    bleed the pump of all air, but now will not start.
    no faults in engine system or immobiliser.
    tryed bumb starting, still nothing.
    i desperatly need help.
    (also if i remove the pump to have it checked or fit another one, will it need coding in.)
    i hope someone can help. please contact on here or on puddweiser@hotmail.com
  2. Re: Help needed badly 1999 tdi
    Mar 2007
    northumberland
    I have a pump if you get stuck for one , I bought it used but have not got round to fitting it, it was taken off a 2000 golf tdi with 95k on it the part number is
    vag part number 038 130 107D, bosch part number 0 460 404 977
    it has the 10 pin plug.
    Fitting the pump involves removing the timing belt and redoing the timing, you need proper gear to do this and vagcom.
    If you want the pump you can have it for £120 delivered.
  3. Re: Help needed badly 1999 tdi
    i gotta check the park number on monday and il get back to you, thank you.
    does the pump need to be coded in using vagcom, or is that just to check the timing. i think the immobiliser runs through the pump and worried the pump wont match to the immobiliser or key.
  4. Re: Help needed badly 1999 tdi
    Mar 2007
    northumberland
    The pump wont be effected by the immobiliser, it should just plug in and work.
  5. Re: Help needed badly 1999 tdi
    thanks mate, il check the park numbers on monday and il get back to you.
  1. Sliding door closing badly
    By wblatchley in forum The Commercial Range
    Last Post: 24-12-2007, 10:38 AM
  2. S3 misfiring very badly...
    By mark_eire in forum Audi A3 - Archive Topics
    Last Post: 22-12-2007, 09:49 PM
  3. How badly do Vw's leak?
    By Flash2 in forum Chat - Anything with wheels
    Last Post: 06-07-2007, 05:44 PM
  4. Golf 1999 1.8t Gti 20 Valve Help Needed
    By isetta in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-04-2007, 08:31 AM
  5. chipped passat 115pd behaving badly
    By timmythedog in forum Passat - Archive Topics
    Last Post: 17-04-2006, 08:23 PM
