Thread: S3 Longitudinal Accel Sensor
  1. S3 Longitudinal Accel Sensor
    May 2007
    Berkshire
    Hello,
    Can anyone help with this fault code below? The ESP and ABS lights are on pretty much permanently on all the time now. Every time the fault code is cleared it appears when the controller is closed on VAG Com.
    The front ABS Sensors were changed about 2 months ago, the brake light switch has been replaced and this seemed to work for about a week. Now I've had a look at the wiring for the sensors and they look ok.
    Anyone got any ideas except form getting fleeced by Audi for a new Accel sensor?
    Cheers.
    VAG-COM
    Windows Based VAG/VAS Emulator
    Version: Release 409.1-US
    Dealer/Shop Name:
    Workshop Code: 000 00000
    Diagnostic Trouble Code Report
    Thursday, 07 February 2008, 16:55:45
    VIN Number: License Plate:
    Mileage: Repair Order:
    Control Module Part Number: 8N0 907 379 E
    Component and/or Version:
    Software Coding: 18448
    Work Shop Code: WSC 06435
    1 Fault Found:
    01279 - Longitudinal Acceleration Sensor (G251)
    27-00 - Implausible Signal
    Readiness: N/A
  2. Re: S3 Longitudinal Accel Sensor
    Had the same problem with my S3. The only thing that fixed it (and there was a lot of stuff changed over a period of about two months) was a new Longitudinal Sensor.
  3. Re: S3 Longitudinal Accel Sensor
    May 2007
    Berkshire
    I figured that would be the case!
    Can you remeber the cost involved?
    Cheers for the help anyway.
  1. TT longitudinal sensor calibration
    By Academy in forum Archive posts
    Last Post: 24-09-2007, 04:38 PM
  2. Drop in RPM's during normal accel
    By kennbart in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-08-2007, 05:02 AM
  3. 2000 1.8t quat - over rev on accel
    By jerrygoulis in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-07-2007, 09:36 AM
  4. Thrust Sensor same as Map Sensor?
    By whistleblower in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-05-2007, 06:03 PM
  5. MAF Sensor
    By shahabudeen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-04-2007, 11:09 AM
