Thread: A4 TDi Onboard Computer
  1. A4 TDi Onboard Computer
    smep Guest
    Hello I am new to the site,Have just bought a sport version and disappointed that there is no on board computer.I welcome advice as to whether these can be fitted /cost and where to buy please.Thanks,Steve.
  2. Re: A4 TDi Onboard Computer
    Hi I'm also a new member and I have also just bought a 04 A4 avant sport with factory fitted s-line styling and that has no computer, how rubbish!! Ive upgraded from a 1.9tdi sport passat estate and that had one!
    Whats the cost involved to get one???
  3. Re: A4 TDi Onboard Computer
    Cheshire, or my A6
    I don't know the cost involved or anything but, don't blame Audi or anything because it is most possible that the person who bought it brand new didn't tick the on-board computer option. Nearly everything is an option on an Audi so buying a new one can become very expensive!
    Paul
  4. Re: A4 TDi Onboard Computer
    Apr 2007
    Hampshire
    What I presume your after is the DIS (driver information system) which uses the display in between the speedo & tacho? This can very easily be retrofitted simply by replacing the r/h steering column stalk that controls the wipers for the version with the extra buttons you need. This then needs to be programmed which can be done yourself through vagcom if your up to the challenge! Thats all folks, not an expensive part from an Audi dealer, Vagparts etc etc. Do a search on the site for DIS retrofit and you should come across the in-depth instructions as this has been discussed plenty previously.
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  5. Re: A4 TDi Onboard Computer
    smep Guest
    Thanks for the advice which is helpful.Don't know that I have the confidence to try it myself so as it seems that it can be done I will ask at the Audi dealer here in Hull for a price which I suspect will be quite expensive.Again thankyou.Steve.
  6. Re: A4 TDi Onboard Computer
    Apr 2007
    Hampshire
    They'll charge you a couple of hours labour i'd expect to do the job which at somewhere in the region £120+VAT per hour wont be cheap! This can be done in under an hour by a decent independant garage that has a suitable diagnostic system. Check for independant VW/Audi/Skoda specialists in your area as they will be a lot cheaper on labour, you can even buy the part for them just to fit it!!
  1. A6 onboard computer
    By richards123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 02-05-2008, 03:37 PM
  2. 1.9 tdi onboard computer
    By mikegally in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2008, 10:41 AM
  3. Oil temperature - onboard computer
    By A3 Newbie in forum Audi A3 - Archive Topics
    Last Post: 23-08-2007, 09:49 AM
  4. OnBoard Computer
    By botabaixo in forum Passat - Archive Topics
    Last Post: 03-03-2007, 12:08 PM
  5. Onboard computer
    By jaspergarland in forum Passat - Archive Topics
    Last Post: 15-02-2007, 05:15 PM
