Thread: Rumbling / Grating Noise
  1. Rumbling / Grating Noise
    My '99 TDi 115 estate has started making an absolutely terrible noise.
    Its a rumbling, scraping, knocking type noise that seems to be coming from the front of the engine bay. Its clearly audible from inside the car and out. Its constant but rises and falls with the engine speed, although I don't think its coming from within the block or cylinder head.
    The engine and transmission / clutch are (currently) performing normally, as are the ancillaries (alternator, water pump, etc.)
    It started quite suddenly and is definitely getting worse.
    Other than that, all I can say is that its very loud and sounds expensive
    Anyone know what it might be?
    Regards, Desperate noobie
    P.S. I ran low on oil a couple of weeks back, just until the warning light came on, but I filled it up straight away so I wouldn't have thought this would be related........
  2. Re: Rumbling / Grating Noise
    ireland
    if it from the front of engine check waterpump and timing belt tensioner
  3. Re: Rumbling / Grating Noise
    Will do paulp. Thanks.
    One other thing that may be worth mentioning is that when I topped up the oil, I over filled it by about 1/4 inch above Max on the stick, but the oil warning light stayed on (yellow) and has been on ever since. At first I put it down to a clever sensor that was telling me that I'd put too much oil in, but now I'm not so sure......
  4. Re: Rumbling / Grating Noise
    Mar 2007
    birmingham
    hi i jus developed the same problem 150bhp bora , loud knocking noise from manifold or sumwhere , scared 2 drive it sounds really bad ! , have you had ny luck ? need info thankss
  5. Re: Rumbling / Grating Noise
    "hi i jus developed the same problem 150bhp bora , loud knocking noise from manifold or sumwhere , scared 2 drive it sounds really bad ! , have you had ny luck ? need info thankss"
    May be the same thing.... mine was definitely coming from the front (belts and pulleys) area of the engine bay.
    Turns out it was the bearing for the pulley / shaft that supports cooling fan. If yours is the same thing, you should see a significant amount of "float" on the pulley as the fan turns.
    Mine's at the garage now waiting for the replacement part (which seems strangely difficult to get hold of) I've had a load of other work done at the same time (cam belt, water pump, tensioner, Frt disks and pads, suspension arms, Anti-roll Bar drop links, Major Service and a couple of minor repairs), slightly worried now that I'm gonna have to sell the wife and kids to pay for it all
  6. Re: Rumbling / Grating Noise
    Quote Originally Posted by n793 View Post
    Gearboxes are pretty sh1te on Bora's, could be bearings.
    2019 Urus, 2020 RS7
    2014 RS6, 2018 RS5, 2016 RS3, 2019 RS3
    2011 RS5, 2008 S5 V8
    2007 A4 2.0, 2008 Passat 2.0 TDI
    2005 Bora 1.9 TDI, 2000 Bora 1.6 , 1989 Polo 1.4
  1. Air con fan rumbling.
    By Mike McKinstry in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-08-2010, 10:57 AM
  2. Rumbling exhausts
    By rich_bro in forum Archive posts
    Last Post: 31-07-2007, 12:12 PM
  3. Grating noise from the front of my polo
    By frasermac in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2007, 04:29 PM
  4. A4 2.8 Rumbling noise
    By markcass in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 04:54 AM
  5. engine bay grating noise
    By COLIN in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-05-2006, 01:07 PM
