Thread: Court Hearing - Information required...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
  1. Court Hearing - Information required...
    Good afternoon, I wonder if some of you would be able to help me.
    I need some information regarding damage caused to the engine of a VW Golf TDi in regard to oil pump failure, damage to the turbo, and also what damage this could cause to the engine?
    All help and advice fully appreciated.
  2. Re: Court Hearing - Information required...
    134 Post(s)
    2012 Post(s)
    Can we have a little more background information such as car year and engine code plus a story about what has happened?
  3. Re: Court Hearing - Information required...
    For sure, the vehicle age is 2000 (W) I do not have the engine code sorry.
    The car came in for a service and timing belt change, this was conducted, 10 days later the customer complains that the belt was faulty/came loose and damaged the engine. We sent the belt away to be tested, we had a report back showing no inherent fault.
    We rebuilt the engine, and started the engine, within three mins, the same thing happened and damaged a valve.
    After further investigating we had noticed the oil pump was not working, this inturn has damaged the turbo.
    If no oil was getting into the pump and then on to the turbo, what damage could this cause?
  4. Re: Court Hearing - Information required...
    134 Post(s)
    2012 Post(s)
    That is a very depressing tale. What is the vehicles registration number?
  5. Re: Court Hearing - Information required...
    Hope that helps, the chap has now put in a re-con for £3.5k and is looking to sue the garage, but the engine could have been rebuilt at a fraction of the cost.
    I am just gathering information, and wondering if the oil pump was not recieving oil and not able to distibute oil, would this then cause the engine to seize, and what sort of damage should be expected?
  6. Re: Court Hearing - Information required...
    134 Post(s)
    2012 Post(s)
    Hope what helps?
  7. Re: Court Hearing - Information required...
    Anybody?
  8. Re: Court Hearing - Information required...
    134 Post(s)
    2012 Post(s)
    I only got that number in the notification mail, not on the screen. It is a Golf 4 Y chassis (2000) with a 110PS VEP TDI engine, the reg document incorrectly states that the car has 115PS which is a PD TDI AJM engine. How did the oil pump fail, was it the chain, tensioner or sprocket bolt?
  9. Re: Court Hearing - Information required...
    Feb 2007
    Nottingham
    Hm, well hang on a minute, it seems you are from the garage? In which case surely you should be consulting legal aid and using the expert knowledge that you already have in this area rather than consorting a motoring forum??
    You may think I'm being helpful yet sarcastic, this is only because I feel I need to help you to help yourself in the future
  10. Re: Court Hearing - Information required...
    Mar 2007
    Yorkshire
    Quote Originally Posted by motyourcar View Post
    You, a professional garge, rebuilt the engine but didn't check the oil pump was working
    This is a wind up isn't it?
    In answer to your question, if you run an engine without oil feed it will score the bearings in the turbo making it an expensive paperwieght, wreck the big ends, main bearings, camshaft bearings, and a lot more. In others words, the huge lump of pig iron which used to be an engine, isn't one now.
    Is there no oil pressure warning light on those things?
    2007 Audi A6 3.0 TDi quattro S line manual saloon
    1975 Rover P6 4000S 5 speed
    Time flies like an arrow
    Fruit flies like a banana
  1. ID3 tag information from Ipod?
    By jacktl in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-01-2008, 01:11 AM
  2. Information needed.
    By vdubnewbie in forum Archive posts
    Last Post: 17-12-2007, 10:20 AM
  3. Information please !
    By redexcel in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-07-2007, 10:05 PM
  4. Information required on www.ukpassats.co.uk
    By Shinman in forum Chat - Completely Off Topic
    Last Post: 10-04-2007, 12:07 PM
  5. New Golf GTi Information
    Last Post: 13-12-2004, 09:44 PM
