Thread: 1.8T Turbo on the way out?
Results 1 to 10 of 17
  1. 1.8T Turbo on the way out?
    What would the signs be of a Turbo needing changing?
  2. Re: 1.8T Turbo on the way out?
    A, A
    What problems do you have ?
    Just another B7 Estate
  3. Re: 1.8T Turbo on the way out?
    Dec 2006
    Quote Originally Posted by ggmoney99 View Post
    Whats issues do you have??
    Rick
  4. Re: 1.8T Turbo on the way out?
    25% loss in power. Don't feel the turbo surge so much in 1st and 2nd Gear.
    You can feel the tourqe in 3rd but its not as strong....
  5. Re: 1.8T Turbo on the way out?
    A, A
    You need a Fault Code scan.
    See if there are any obvious causes of the power loss.
  6. Re: 1.8T Turbo on the way out?
    Problem Solved.
    I unplugged the air mass sensor. And was all back to normal.
    Replaced air mass sensor (MAF) on saturday and all power is back to normal....
  7. Re: 1.8T Turbo on the way out?
    A, A
    Problem Solved.
    Nice one, esually is the first point of call.
  8. Re: 1.8T Turbo on the way out?
    Sep 2007
    Quote Originally Posted by mluton View Post
    I think im having the same problem. Can you please tell me where and how this is done.
    Many thanks.
    Connor.
    Rugby League. The Best Sport In The World. Even Better When You Support Wigan Warriors.
  9. Re: 1.8T Turbo on the way out?
    Air mass sensor is attached to the air box. It's a tube with an element in. There is an electrical conector attatched to it.
    Air Box --> Air Mass Sensor --> Pipe --> Turbo
    Unplug the air mass sensor and go for a drive. You have to squeeze the catch quite hard to get it off.
    Error lights will appear on the dash. Put your foot down and see what happens....
    If you can, you might want to get the error codes cleared off afterwards. Find someone with the machine to do it. eg vag-com, X431 etc etc..
  10. Re: 1.8T Turbo on the way out?
    Sep 2007
    Thank you. I will give it a go.
  1. tdi 150 bhp turbo
    By motorhead in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2007, 11:15 PM
  2. mk4 1.8T - what Turbo
    By Bevsy in forum Golf MK4 - 1999 - 2004
    Last Post: 20-11-2007, 08:12 PM
  3. turbo lag
    By unhinged pastie in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2007, 04:36 PM
  4. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  5. Turbo Dip
    By mkpp786 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 02:39 AM
