Thread: VW Passat B5 - ABS - Dash warning light flicking on intermittently
  1. VW Passat B5 - ABS - Dash warning light flicking on intermittently
    Feb 2012
    Waterford ireland
    Hi
    For the last while I notice the ABS warning light flicking on every 50 Miles or so for no reason.
    When this happens I experience a brief "pull" while the ABS appears to momenterily kicks in.
    Have had it with the VW dealers who cannot find anything.
    Any ideas out there.
    Thanks in advance.
  2. Re: VW Passat B5 - ABS - Dash warning light flicking on intermittently
    Norfolk
    This type of fault is almost impossible to trace because finding it relies on the ecu logging an error that you can pick up in diagnostics. If VW dealer didn't find any faults logged, you may have to wait until the car logs a fault. Trying to find the fault any other way will be very time consuming and possibly very costly as you keep replacing suspect parts. You may be experiencing an intermittent abs ecu fault, this happens on a number of VAG vehicles and usually results in the ecu being repaired or replaced.
  1. Please Help Oil warning light and buzzer comes on intermittently
    By volkswagen 1200 in forum 100 - 200 - Turbo - 100 S4
    Last Post: 26-03-2011, 12:00 AM
  2. ABS light intermittently on
    By kevdood in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2010, 10:32 PM
  3. ESP Warning light comes on intermittently (A4 B6 Tdi 130)
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-08-2008, 03:06 PM
  4. Passat 2001 1.8T - ABS Warning Light On!
    By richard child in forum Passat - Archive Topics
    Last Post: 19-01-2007, 08:40 PM
  5. Passat 2001 1.8T - ABS Warning Light On!
    Last Post: 17-01-2007, 05:38 PM
