Thread: passat 130 tdi cooling system
Results 1 to 10 of 39
  1. passat 130 tdi cooling system
    Jan 2008
    hello lads back again i drove my car for six hours solid yesterday i use the car for a taxi i pulled into a garage to check the water and the water in the expansion tank was freezing i took off the cap and there was zero pressure the temp gauge was normal the heaters were normal i tried bleeding it today pulled the pipe back to expose the bleed hole lifted the expnsion tank but no water came out till i squeezed the hoses it woulnt just run out freely also the return hose shows no sign of water until i squeeze the hose i thought maybe the water pump but if the pump was knackered wht would the heaters be getting hot any suggestions would be really appreciated also its had a new cylinder head fitted by vw and the problem started 3 days later could it be linked i tried bleeding with engine not running and running it made no difference cheers for reading this bill
  2. Re: passat 130 tdi cooling system
    Aug 2007
    My system was not bled properly at first when I put it back together and so the heater was not working properly, contrary to your experience. When I drained the system it seemed to have left a plug of coolant behind in the heater that was released when I refilled it without initially bleeding. It appeared to be full but the heater not working gave it away and I had to add another 1.5L during the bleed process.
    I lifted the header tank and bled without the engine running. Then ran the engine for 5 minutes and topped up. It has been OK since.
    There should be pressure in the header tank if it is getting up to temp - but in the cold spell it is possible that it is not and may be affected even more by a thermostat stuck open. Can you feel any warmth at all in the radiator ?
    You might want to try blanking off part of the radiator while driving and see if you can get any increase in temperature. If so then I would suspect the thermostat.
    I have to run my land rover with the rad blanked off almost completely as it runs cold otherwise - just a fact of life !
  3. Re: passat 130 tdi cooling system
    Jan 2008
    Quote Originally Posted by passing View Post
    thanks for reply mate i drove it yesterday for about an hour and half and the bottom hose was cold the top one was hot can i just ask ,when you bled yours did the water run freely out the bleed hole cos when i tried to bleed mine the water woulnt come out unless i squeezed the pipe also do you know what that sensor is on the bottom hose i think its a sensor theres a couple of wires going to it cheers bill
  4. Re: passat 130 tdi cooling system
    Aug 2007
    top hose hot sounds good.
    With the header tank above the bleed hole the coolant was flowing out quite freely. Assume you have new coolant and no crud blocking the hole ?
  5. Re: passat 130 tdi cooling system
    Jan 2008
    hi its had anew cylinder head from vw with the proper coolant i lifted the header tank above the bleed hole i even took the pipe off and there was no water coming out till i squeezed the top hose is it normal for the bottom hose to be cold when the engine is hot ? cheers bill
  6. Re: passat 130 tdi cooling system
    Has this started ever since you had the head replaced by vw??
    Ed
  7. Re: passat 130 tdi cooling system
    Dec 2007
    North Yorkshire
    When my water pump went the engine temp gauge behaved as normal. The only indication was when we had a hot day the climate control was blowing out hot air no matter what temp it was set at.
    Quote Originally Posted by billza1967 View Post
  8. Re: passat 130 tdi cooling system
    Sep 2007
    yorkshire
    Quote Originally Posted by eko View Post
    What do mean by went? You mean it started leaking!
    2003 AUDI AVANT SPORT TDI
  9. Re: passat 130 tdi cooling system
    Dec 2007
    North Yorkshire
    Quote Originally Posted by passat>sport View Post
    It was not leaking, the impeller has detached so it was not spinning.
  10. Re: passat 130 tdi cooling system
    Sep 2007
    yorkshire
    Bill, I drove to work today (9 miles approx) got stuck in the morning traffic, so took about 45 mins to get there.
    Guess what! the bottom hose and header tank bottle water were still cold. Temp gauge was reading half way.
    Don't take this as your car is ok but more of something to think about.
  1. cooling system
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2008, 02:29 PM
  2. Air con not cooling in my '97 Passat
    By mcstu74 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 07:27 PM
  3. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  4. No pressure in cooling system
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2007, 06:48 PM
  5. Mk3 golf 2.0 gti / air in cooling system
    By Happy_Trucker in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2006, 01:26 AM
