Thread: passat 130 tdi cooling system
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. Re: passat 130 tdi cooling system
    #21
    Quote Originally Posted by passat>sport View Post
    Bill, I drove to work today (9 miles approx) got stuck in the morning traffic, so took about 45 mins to get there.
    Guess what! the bottom hose and header tank bottle water were still cold. Temp gauge was reading half way.
    Don't take this as your car is ok but more of something to think about.
    If your heater is on the heater will be dumping the excess heat into the car interior, Bills Passat is ok if he has the heater on, its when the main rad is needed he has problems.
  2. Re: passat 130 tdi cooling system
    #22
    Quote Originally Posted by caldirun View Post
    thanks for the replies lads im going to change the thermostat at the weekend for what it costs and see if that makes a difference its worth a try im sick of sweating like hell lol ill let you know how i get on cheers again lads
  3. Re: passat 130 tdi cooling system
    #23
    Sep 2007
    yorkshire
    You've been reading your haynes manual again.
    And what problems exactly is bill having caldirun?
    His bottom hose is staying cold and the header tank water is also staying cold! This is very normal on PD tdi car in this cold weather. HELL, He's a taxi driver (and still not broke down)
    No, it dosn't tell you that in the haynes . LOL.
    2003 AUDI AVANT SPORT TDI
  4. Re: passat 130 tdi cooling system
    #24
    [quote=passat>sport;129637]Bill, I drove to work today (9 miles approx) got stuck in the morning traffic, so took about 45 mins to get there.
    /[quote]
    12 MPH by my reckoning, no wonder your bottom hose was cold, I could run that without taking my jog bottoms off. Turn your heater off and take it for a real drive, that'll warm your hose up.
    To see Bills probs, it helps to read his posts before replying!, GF
    Have you something against Haynes manuals, are you one of those who presses all the buttons before reading the instructions?
  5. Re: passat 130 tdi cooling system
    #25
    Basingstoke
    Quote Originally Posted by billza1967 View Post
    i went to adjust the drivers side mirror and both mirrors were moving could that have anything to do with it cheers bill
    They're meant to!
  6. Re: passat 130 tdi cooling system
    #26
    west yorkshire
    Passat>sport is correct in what he is saying. The VW tdi have a very good design in which the thermostat stays shut (especially in cold weather) for long periods of time. Even if you drive at motorway speed in cold weather like we are having, the radiator will cool that much that the thermostat will just shut again (hence a cold bottom pipe again) because there is no water flow going through it.
    I also thought there was a problem at first but soon found out it is very normal on these engines.
    By the sounds of it, you do a lot of driving with you being a taxi. If there was something wrong you would surly know about it by now.
  7. Re: passat 130 tdi cooling system
    #27
    Quote Originally Posted by davey_g23 View Post
    They're meant to!
    cheers davey ive had the car nearly a year and only noticed it the other night seems a bit odd as to why cheers bill
  8. Re: passat 130 tdi cooling system
    #28
    Basingstoke
    I can only guess it's so that if you want to lower them a bit while reversing they both go down? No idea why really, but they all seem to do it.
  9. Re: passat 130 tdi cooling system
    #29
    i did break down one night mate was driving normal and it just quit had 2 passengers in and had to radio for another taxi i was embarased to say the least it wasnt overheating but it took a good hour to get it started by then it had cooled down but since i blanked off the egr it starts everytime but i get no response from the throttle for a few seconds it does this every time but when i put my heaters on it starts no problem every time i thought id try putting the heater on cold and the car still started and i thought well it must be electrical but then it started acting up again so its got to be on hot and its got to be on at least four bars so its got to be something to do with the cooling system i would of thought theres no fault codes at all everyone who looks at it dont have a clue i dont know what to do next its got me totally fed up an auto electrician put a resistor in one of the four wires on the coolant temp sensor and it started everytime he said it was telling the ecu that the engine was colder than it actually was the only problem was i was gettin 100 mile for 20 quid so i took it off even the electrician didnt know why it worked ok with a resistor in but it still goes back to the cooling system if the pump and thermostat are ok what else on the cooling side can cause a fault like that the *********** have admitted they havent got a clue they said ecu fault so i changed it and it was no different more cash down the drain cheers for all your comments lads i would love to fix it its a real mystery
  10. Re: passat 130 tdi cooling system
    #30
    Sep 2007
    yorkshire
    i drove my car for six hours or so yesterday l use the car for a taxi, i pulled into a garage to check the water and the water in the expansion tank was freezing i took off the cap and there was zero pressure the temp gauge was normal and the heaters were normal
    I answered the above Question.
    it helps to read his posts before replying! are you one of those who presses all the buttons before reading the instructions?
    I always read all the thread (as the above shows)
    You obviously do not!
  1. cooling system
    By billza1967 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2008, 02:29 PM
  2. Air con not cooling in my '97 Passat
    By mcstu74 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-01-2008, 07:27 PM
  3. Fault affecting alternator, power steering and cooling system
    By valdid_shaw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2008, 01:56 PM
  4. No pressure in cooling system
    By 31satara in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2007, 06:48 PM
  5. Mk3 golf 2.0 gti / air in cooling system
    By Happy_Trucker in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2006, 01:26 AM
