Thread: Sill trim replacement...
  1. Sill trim replacement...
    Mar 2007
    My the decorative strip?? on my O/S GTi sill trim has started to rust underneath (appears only the upper strip has rusted)...are these still available from VW if so anyone any idea how much they are ? Do I need to get fixing clips also if I am able to get a replacement...I don't want to pull the old strip off to have a look in case I can't get a replacement
  2. Re: Sill trim replacement...
    portsmouth
    yes they are still avalible not expensive at all as had to order new ones for mine i have a spare one brand new in shed if you want me to post
    sticky
  3. Re: Sill trim replacement...
    Mar 2007
    Cheers Sticky....is the one you have for a 3 or 5 door (mines 3)...does it have the end caps?....and what does postage from lalaland come to???
  4. Re: Sill trim replacement...
    Mar 2007
    Just went into the local $tealership and picked one up...actually in stock....5mins later fitted...thats the kind of job I like!!!Thanks again Sticky for your offer
  5. Re: Sill trim replacement...
    portsmouth
    no problem free to a good home,anyone else if they want it, as to postage unless you are in guatimala or fiji dont worry just pm me will send on glad you got a new one sorted domross
    smiley faces all round
    regards stickyhappy days fellow dubbers
  6. Re: Sill trim replacement...
    How much do u want for it,??? is it drivers side???
  1. So I've damaged the sill of the car with a jack...
    By dwalker109 in forum Archive posts
    Last Post: 26-01-2008, 05:01 PM
  2. Removing plastic trim on sill of the door
    By sheka in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-01-2008, 08:47 AM
  3. interior trim replacement? A3 05 5dr
    By boo77 in forum Audi A3 - Archive Topics
    Last Post: 18-01-2008, 12:01 AM
  4. Door Sill Plates
    By Mimmo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2007, 06:53 PM
  5. Sill Trims
    By gholian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-04-2007, 01:13 PM
